New To The Forum. Considering a Shapeoko XXL.
FatPoppy
Post by FatPoppy » Sat Oct 19, 2019 7:57 pm
Hi All,
I'm new to this Forum.....New to Shapeoko.....New to Vector Type CNC Machines...... I am considering a Shapeoko XXL.
I have had a General i-Carver 40-913 CNC (which is a raster type machine) for about nine years now. I have enjoyed it well. One of my concerns is the belts. Is that a problem? What kind of life/breakage do they have? Are there any "Problem Areas" that should be consider before buying? Is the software easy to learn? I have also questions as to which router is best.
Thanks,
FatPoppy
Re: New To The Forum. Considering a Shapeoko XXL.
Post by WillAdams » Mon Oct 21, 2019 2:41 am
The belts are amazingly strong in tension --- some folks have replaced the stock fiberglass-reinforced with steel core belts, and another option is Kevlar. Brandon (ImprobableConstruct) had over a year of hard use on his machine before breaking a belt, and since then we've upgraded from MXL to 9mm wide Gates GT2.
Problem areas are usually a matter of familiarizing oneself with the eccentric nuts, V wheels, and belt tensioning --- all stuff covered by the checklist: https://docs.carbide3d.com/general-faq/ ... checklist/
The software is straight-forward --- see: https://docs.carbide3d.com/assembly/car ... tutorials/ --- if you get stuck on a file or project, send it in to us at support@carbide3d.com and we'll do our best to help.
Either router is fine, see: https://wiki.shapeoko.com/index.php/Spi ... act_Router
