Rapid Rate
Jeff
Rapid Rate
Post by Jeff » Sat Feb 22, 2020 12:47 pm
Can some one tell me how to find out what the rapid rate of a Shapeoko XXXl is.
I want to put that info into Vcarve Pro to get more accurate tool path run times.
Jeff
Re: Rapid Rate
Post by WillAdams » Sun Feb 23, 2020 7:36 pm
The settings shown at: https://docs.carbide3d.com/software-faq ... -settings/
are:
$111=5000.000 (y max rate, mm/min)
$112=5000.000 (z max rate, mm/min)
but please see: https://community.carbide3d.com/t/testi ... ings/19280
Jeff
Re: Rapid Rate
Post by Jeff » Wed Feb 26, 2020 12:00 am
It is interesting that almost every time I post a question here ,I don't get a straight answer but directed to some other place the that means nothing to meat all .I am not a programer so I would not try to change any settings in Carbide Motion
Jeff
Re: Rapid Rate
Post by WillAdams » Thu Feb 27, 2020 2:38 am
I'm afraid that if you want to change the defaults, that currently requires that one uses the MDI to set them as one would when calibrating for belt stretch:
https://docs.carbide3d.com/shapeoko-faq ... t-stretch/
Jeff
Re: Rapid Rate
Post by Jeff » Thu Feb 27, 2020 11:48 am
I guess I did not make my self clear. I do not want to make any changes to the settings in CM I am just looking for the speed rate for the rapid
movement from say the home position to the front left corner.
Or whatever the fasted movement of the machine is
Jeff
Re: Rapid Rate
Post by WillAdams » Sat Feb 29, 2020 3:40 am
I provided that above with a link to where I got them from.
