Reduce the "hello Word" example
nio
Post by nio » Sun Apr 22, 2012 8:40 pm
i mean, it's too big and it doesn't fit in a A4....
other examples it seems smaller...
http://www.shapeoko.com/wiki/index.php/ ... _world.JPG
i'm using grbl shield, and grbl 0.8a
RedOko
Re: Reduce the "hello Word" example
Post by RedOko » Sun Apr 22, 2012 9:00 pm
Try downloading pycam. It's basic Cnc software that's easy to learn and play with. You can generate your own Goode to run.
Luis
aka "RedOko"
nio
Post by nio » Sun Apr 22, 2012 9:04 pm
Could be for this line in the example??
G20 G90 G64 G40
is not G20 for inch mode??
nio
Post by nio » Sun Apr 22, 2012 10:09 pm
Ok RedOko, but i'd like test it to adjust the machine, but i don't understand why i'm the only i've this problem, or the rest of the people have readjust the example??
Aaron Seltzer
Post by Aaron Seltzer » Sun Apr 22, 2012 10:16 pm
nio wrote:Ok RedOko, but i'd like test it to adjust the machine, but i don't understand why i'm the only i've this problem, or the rest of the people have readjust the example??
Maybe you have 200 steps/rev stepper motors instead of the 400 step/rev motors. That would make yours seem twice the size...
RedOko
Post by RedOko » Sun Apr 22, 2012 11:58 pm
Aaron is correct on this one. Quick way to check it is this way. I'll assume you are using grblgcodesender.
Type the following, ignore the comments
G20 G90 "inch mode, absolute coordinate"
G1 X1.0. "X should move just 1 inch"
If you move 2 inch, change the pulse/mm by dividing it by 2.
Luis
aka "RedOko"
nio
Post by nio » Mon Apr 23, 2012 8:34 am
i've the motors included in the kit (kickstarter)....
i'm going to test these parameters
nio
Post by nio » Mon Apr 23, 2012 9:12 pm
Ok guys, the problem was themotors are 200 step/rev (X/Y axis) 400 step/rev (Z axis)... now i've got a normal size.....
Thanks again...
