Upside down and Backwards
DevinTX
Post by DevinTX » Sat Jan 26, 2013 4:08 pm
After a year of health issues I have finished assembling my ShapeOko. I ran the "ShapeOko Test" and the print is upside down and backwards. I have tried different settings in $7 and can't seem to invert the Y axis correctly. Can someone offer a solution?
Devin
ShapeOko # 207 / Dual Y Drive / Acme Upgrade / Belt on outside / Working on expansion
madmike88
Re: Upside down and Backwards
Post by madmike88 » Sat Jan 26, 2013 4:38 pm
Rewrite the stepper motor. Swap one pair only of a stepper driver pair.
levlandau2
Post by levlandau2 » Sat Jan 26, 2013 4:43 pm
Can you post the output of your GRBL when you type in $ so we can see your settings?
If the software inversion does not work for you, another option is to invert the stepper motors by switching the wires. First turn off all of the power to the steppers (or you will fry your drivers), then reverse one pair of wires (e.g. switch locations of blue and red wires) for the axis you want to reverse.
DevinTX
Post by DevinTX » Sat Jan 26, 2013 8:22 pm
Thank you for the quick response.
Here are my settings
Grbl 0.8a
$0 = 43.74 (x)
$1 = 43.74 (y)
$2 = 188.95 (z) ---Using ACME Screw
$3 = 30
$4 = 500
$6 = 0.10
$7 = 28 (00011100)
$8 = 50.00
$9 = 0.05
Thanks again for the help
madmike88
Post by madmike88 » Sat Jan 26, 2013 8:48 pm
http://www.shapeoko.com/wiki/index.php/ ... nvert_Bits
$7 should be 96 to invert both X and Y axis.
DevinTX
Post by DevinTX » Sat Jan 26, 2013 9:32 pm
TY
I ended up "flipping" the wires and that fixed the prob. I am now on to mounting my DW660 and we will see what happens
Devin
