3/4 dia 2 flute straight bit
Jeff
Post by Jeff » Mon Mar 01, 2021 2:57 pm
I am using a 3/4 " dia 2 flute bit to do a pocket will I be able to use the probe to set my XYZ and will htat big of bit work on the bit setter as well
Thanks Jeff
Jeff
Re: 3/4 dia 2 flute straight bit
Post by Jeff » Mon Mar 08, 2021 1:25 pm
I guess I will answer my own question Yes you can
Post by WillAdams » Mon Mar 08, 2021 2:15 pm
Apologies.
This forum isn't as active as the others:
https://community.carbide3d.com/
To expand on your answer --- any endmill which is either narrow enough to fit on the button (a bit less than 11mm diameter) or which has structure at the center even with the cutting edge will work.
