Excited!!
kerrycorcoran
Excited!!
Post by kerrycorcoran » Mon Jul 22, 2013 10:41 pm
Just ordered my kit; hoping it gets here quickly. Can't wait to start the build!!
Kerry
zerblatt007
Re: Excited!!
Post by zerblatt007 » Tue Jul 23, 2013 2:25 pm
Congratulations!
It is worth waiting for.. :-D
Re: Excited!!
Post by WillAdams » Tue Jul 23, 2013 2:31 pm
My suggestion for your wait is to start planning out projects to do --- a lot of new users get bogged down after assembling the machine when confronted w/ software issues in CAD/CAM.
Download Inkscape, or some other tool which is suitable to the sorts of projects you want to do and start drawing, then start converting files to G-Code and checking them in a simulator / previewer.
William
selektha
Re: Excited!!
Post by selektha » Tue Jul 23, 2013 2:47 pm
Im one of those new users that WillAdams mentioned :) but now I feel rather happy that I can cut simple shapes, now I just have to pick a god CAD,CAM software.
kerrycorcoran
Re: Excited!!
Post by kerrycorcoran » Tue Jul 23, 2013 2:49 pm
WillAdams wrote:My suggestion for your wait is to start planning out projects to do --- a lot of new users get bogged down after assembling the machine when confronted w/ software issues in CAD/CAM.
William
William,
I have created a few drawings in Sketchup, exported to DXF. Opened those files in Cambam and created the g-code. I then used Mach 3 to run the g-code. Now in all honesty, it looks like it all works, but not sure how it would go in "real world" ;)
I just read a post that Mach 3 does not work with the stock configuration? Is that correct? Is there a different software, other than Mach 3 I should mess around with?
I understand the workflow (design(CAD), Generate code (CAM), Cut (Mach3), but not sure if those are the best software(s) to use for the Shapeoko.
I am open to suggestions to make the learning curve easiest.
Re: Excited!!
Post by WillAdams » Tue Jul 23, 2013 2:59 pm
You're way ahead of the curve then.
Can't really advise on specifics (I've tried to do a brain dump into the wiki) and don't want to unduly influence your choices (and I don't use SketchUp 'cause of the license, and 'sides, it won't run well on my ancient old Pentium III).
I just use GRBL, so am quite mystified by Mach 3 I'm afraid --- there are some codes which affect GRBL oddly --- we need to puzzle out and document those.....
I don't believe there is a ``best'' in a software stack beyond ``meets my needs and works reliably''.
William
selektha
Re: Excited!!
Post by selektha » Wed Jul 24, 2013 12:59 pm
I started with sketchup but as soon as I tried more advanced shapes I was stoped by the licence that made it impossible to do some simple tricks so I changed to freecad and now I am testing 123d and actual starts to like it but I still have not decided on a good package.
kerrycorcoran
Re: Excited!!
Post by kerrycorcoran » Wed Jul 24, 2013 7:09 pm
Tracking indicated the package will arrive tomorrow afternoon!!
Be nice to get it prior to the weekend to get started on the build.
Perez Turner
Re: Excited!!
Post by Perez Turner » Sat Jul 27, 2013 5:29 am
kerrycorcoran wrote:Tracking indicated the package will arrive tomorrow afternoon!!
The said package has arrived or still in progress? What is the current status of the package?
[Moderator's note: the only purpose of this post was to expose a link in the signature (now removed). It became part of the discussion, so, for clarity, I have not deleted it.]
kerrycorcoran
Re: Excited!!
Post by kerrycorcoran » Sat Jul 27, 2013 5:35 am
Have been testing and tweaking all afternoon. Basically built other than refinement and understanding how to use the tool properly.
