what shop Vac you would recommend for shapeoko
Re: what shop Vac you would recommend for shapeoko
Post by WillAdams » Wed Sep 04, 2013 10:38 am
I described what I want, not what I have.
Here's one inspiration: http://www.shapeoko.com/forum/viewtopic ... 22&p=10510
More forum links:
http://www.shapeoko.com/forum/viewtopic.php?f=11&t=141
http://www.shapeoko.com/forum/viewtopic.php?f=11&t=475
As I noted, I'm using an old vacuum at a low setting.
stephenjbell
Post by stephenjbell » Mon Feb 03, 2014 4:55 am
I bought the $40 version of the Oneida Dust Deputy. It looks good, but I haven't used it yet. I just cut holes in my bucket lid to mount it, and thought I'd pass my file along.
I'm attaching an SVG to cut a bucket lid with the holes at the right placement/size to attach the Dust Deputy. It's generated from makercam.com and has all the feed speeds and everything entered for a DW660 1/8" bit. Change the file extension back to SVG, then open it in makercam.com (or use it in other software as a starting point).
I'm not responsible for anything bad that happens as a result of using this file.
buckethole-makercamsvg.txt
Cut bucket lid for Dust Deputy - makercam.com SVG
(2.07 KiB) Downloaded 165 times
