Metal Dual V wheel And Fishing line pulley Bearing
jkanzaki
Post by jkanzaki » Thu Sep 05, 2013 8:08 am
http://www.robotdigg.com/product/72/Fis ... ey-Bearing
http://openbuildspartstore.com/openbuil ... eel-metal/
Hey Guys,
Just found some Fishing line pulley bearing in robotDigg, I am wondering if they will work for shaepoko if i want to replace all the plastic V wheel to metal?
Also open build also selling metal v wheel, i heard some people on the forum said these can replace the current plastic V wheel is that true?
I am also curious if anyone have try any of these metal V wheel.
Cheers
Shapeoko 1 - dissassemble
PsyKo
Re: Metal Dual V wheel And Fishing line pulley Bearing
Post by PsyKo » Thu Sep 05, 2013 8:27 am
Hello,
They do work pretty well.
See my post about my machine : http://www.shapeoko.com/forum/viewtopic.php?f=30&t=1608
Make sure you have some hard coated aluminium extrusion. They get worned out by the metal wheels...
Shapeoko #736
Post by cvoinescu » Thu Sep 05, 2013 9:38 am
While it's true that the rail wears out, it still works reasonably well even when quite worn, and the loss of precision is acceptable (unless milling PCBs and other tiny stuff). You can simply treat the rail as consumable and replace it when it becomes too worn. That's what Edward does. :)
jkanzaki
Post by jkanzaki » Fri Sep 06, 2013 3:39 am
I don't mind replacing the maker slide if they get worn out.
But does the metal V wheel make that much of a different in x , y , z ?
16 metal v wheel cost almost 70US. Big investment haha
Improbable Construct
Post by Improbable Construct » Fri Sep 06, 2013 5:34 am
Yes. The metal v wheels make a big difference.
You really only need them on the X and Z axis.
The y axis really only takes a radial load on the v wheels, so the delrin wheels are fine.
Shapeoko 2 # 3926 not stock
Shapeoko 3 # 0003
Store:
Twitter:
fasteddy
Post by fasteddy » Sat Sep 07, 2013 4:24 pm
Back to the other part of op's question: Do you think that those line pulley bearings could be used to directly replace the delrin v-wheels?
Post by cvoinescu » Mon Sep 09, 2013 10:52 pm
No, they won't work very well, because the angle of their groove is not 90 degrees. You'll get an awkward contact between them and MakerSlide, won't be as rigid, and they'll destroy the rail even if hardcoated. Plus, unless they have two bearings or a dual-row bearing, so you'll get quite a lot of play.
The OpenBuilds metal V-wheels, however, are a direct replacement for the Delrin V-wheels -- you can even use the same shim and bearings.
