Vote for your favorite ShapeOko spindle solution!
What is your favorite ShapeOko spindle option?
Rotary Tool - generic (specify)
5
4%
Rotary Tool - brand-name, e.g. Dremel 200 or 4000 (specify)
9
7%
Cut-out Tool - e.g., Dewalt DW660 (specify)
24
19%
Compact Router - e.g., Dewalt DWP611 (specify)
29
23%
Trim Router (specify)
12
10%
Carving Tool (specify)
1
1%
DC Spindle (specify)
32
26%
Palm Router - e.g., Bosch Colt (specify)
4
3%
Mini Spindle (specify)
8
6%
Total votes: 124
Re: Vote for your favorite ShapeOko spindle solution!
Post by WillAdams » Sat Feb 01, 2014 3:21 am
A number of people have wanted to try that. One person did try a knock-off, but that had quality issues.
The carving tool has a number of advantages:
- removes the weight of the motor from the gantry
- moves the end mill closer to the gantry, reducing lever effects.
- allows one to place the motor so as to reduce noise
Looking forward to hearing how it works out.
Little Hands
Post by Little Hands » Sun Feb 02, 2014 2:30 pm
I get my Bosch Colt motor mount from Inventables on Monday. The Colt is stock with a 1/4"dia. collet, I have ordered a 1/8"dia. As soon as I cut a few more parts and things with the stock SO2 spindle. I will change over to the Colt. I am upgrading to the Nema 23-140's on Z and X axis. I figure the (2) Nema 17 on the Y axis are good for now also plan to upgrade Rev3 shield w/A4988 drivers. Had to make a Z-Motor mount to get this done (if anyone would like the photo/.DXF I will try to post it?), still working on all the details and stuff but I feel the Colt is going to work nicely...! Any other ideas or comments?
Post by WillAdams » Sun Feb 02, 2014 3:05 pm
Love to have the photo and dxf of the mount plate posted to the wiki.
Curious to see what the runout is on the Colt --- there have been some reports in the past of difficulties w/ it.
Brian
Post by Brian » Sun Feb 02, 2014 4:21 pm
HF cutout tool is cutting alum plate like a champ. .025 doc at 30ipm with an 1/8 carbide altin endmill. 6061 t6 plate
Brian
Shapeoko 2 #I have no idea
Little Hands
Post by Little Hands » Sun Feb 02, 2014 4:49 pm
Not sure of the Colt runout? Dose Anybody...? I will try and post the .DXF for the Z Mount plate today. Where should I post the .DXF? The hole pattern works with the 17 or 23 motors, 3/16" clear acrylic (for now, might need to go with 5/16" or dbl up?). Keep in mind, it has not been tested. Everything does mount, align etc. looks good too!
IN TESTING
Z Mount plate 3.jpg (109.07 KiB) Viewed 3381 times
IN TESTING
Z Mount plate 2.jpg (84.58 KiB) Viewed 3381 times
IN TESTING
Z Motor Mount plate.jpg (94.07 KiB) Viewed 3381 times
Little Hands
Post by Little Hands » Sun Feb 02, 2014 10:04 pm
Sorry about the photo orientation on the last post..? Does anyone know about runout re: Colt. The stock SO2 spindle is not so great....wobble, wobble My kid's are taking the stock SO2 spindle apart as we speak.....? They want to see what and why?
Post by WillAdams » Sun Feb 02, 2014 11:22 pm
The Precisebits folk have a page on this:
http://www.precisebits.com/lab_reports/ ... lt_TIR.htm
but, they also have this page:
http://www.precisebits.com/WayTooCool.htm
That said, it's probably not too hard to do better than the low-end rotary tools.
The Dewalt appeals to me more for various reasons, but for now I'm making do w/ a 1/4" Harbor Freight Trim Router and MLCS 1/8" adapter --- worked okay for my first test cut (circle-diamond-square test --- need to find the inclination to measure it, then repeat w/ the longer bit which I want to use, but looks like the heavier spindle needs more current on the Z-axis, and I'm just not in the mood to open up the Lego brick enclosure the controller is in).
Sprenkle
Post by Sprenkle » Wed Feb 19, 2014 1:38 am
photo (1).JPG (16.58 KiB) Viewed 3230 times
photo 1.JPG (27.32 KiB) Viewed 3230 times
photo 3.JPG (25.8 KiB) Viewed 3230 times
Here is my spindle solution. I have made many cuts with it already including the box and bottle opener in the picture. I just stood the Zipsaw on its end so it was perfectly straight and put it as close to the alum brackets as possible and started hot gluing.
samc99us
Post by samc99us » Wed Feb 19, 2014 2:06 pm
I am using a Dewalt DNP611 on a stock SO2 currently. You can see photos here: http://www.shapeoko.com/forum/viewtopic.php?f=5&t=2602
I like it a lot. It is quiet, punches through anything and about $180 with a precise bits "precision grade" collet set. I did have a dremel before, which did a decent job in plastics and wood, but not something I would use to cut aluminum or acyrlic.
Brian
Post by Brian » Mon Feb 24, 2014 5:16 am
Brian wrote:HF cutout tool is cutting alum plate like a champ. .025 doc at 30ipm with an 1/8 carbide altin endmill. 6061 t6 plate
After I took some measurements on accuracy it was less than desirable. Going to slow it down when i get a dust shoe to keep the shop clean of alum chips. I love the HF spindle though.
Brian
