Pictures of finished machines
Post by edwardrford » Wed Feb 26, 2014 3:00 am
All,
I'm in the process of building a gallery page that shows off a collection of our finished (assembled) machines. If you are interested in having your machine displayed, please reply with the picture attached (min resolution 800x600), and a (brief) description of your setup. This is open to both v1 and v2 owners.
danimal
Re: Pictures of finished machines
Post by danimal » Wed Feb 26, 2014 3:41 am
Does this include heavily modified machines, or those that still closely resemble their shapeoko roots? I am waiting on a couple more parts and I will have my machine back together for some pics.
Shapeoko # 1458
Post by WillAdams » Wed Feb 26, 2014 11:08 am
Shouldn't they all be on the wiki?
http://www.shapeoko.com/wiki/images/7/7 ... mk-iii.JPG
basics in my signature line per Rule #10 ( http://www.shapeoko.com/wiki/index.php/ ... f_ShapeOko ) and everything else is written up on the wiki, but for full disclosure:
Shapeoko 1 #364 (rebuilt)
* ¼″ drive shaft
* inverted belts on the outside (using the NEMA 23 holes)
* aluminum spacers
* double MakerSlide (375mm) X-Axis
* Acme Screw Z-axis
* 1M Y (motor rotated 45 degrees)
* Harbor Freight ¼″ Trim Router spindle
* Zip tie / race track cable management
* Zip tie / eye bolt belt anchors w/ ¼″ aluminum rod and 1" steel
* AtomCNC control board
* enclosure made of Lego bricks
* torsion box bed made of scraps of particle board
* T-nuts and metal-working side-vice for work-holding
I guess I should take a nicer, less cluttered picture....
Post by edwardrford » Wed Feb 26, 2014 3:26 pm
@animal Yes, heavily modified machines are welcome! The idea for the page is too show off the variety of assembled machines.
@will there might be some on the wiki but this isn't a mutually exclusive thing. Again, the idea is to have a more public facing page to show off our machines.
I'm sure once you see the page, It will make more sense to everyone. I need at least 16 machines to complete the page.
Sent from my SCH-I545 using Tapatalk
criznach
Post by criznach » Wed Feb 26, 2014 7:10 pm
I've been steadily upgrading my Shapeoko 2 for cutting larger model airplane parts, signs, and added rigidity for cutting metal.
12v LED work lights on Y rails.
Makita RT0701c router.
Custom Makita mounts based on the DW660 mounts.
Dust shoe based on the WillAdams design.
Mechanical limit switches.
Seeed Studio protoshield for limit switch noise filtering.
Doubled Y axis rails with 40x20.
T-slot bed made from Mitsumi 80x20 and 40x20.
Added 2 additional v-wheels to Z axis.
Drag chain from Inventables.
Work clamps based on the Inventables design.
Rotated X/Y axis so the former Y axis is now the X. Home is bottom left in the photos.
As I did the Y upgrade I decided to get rid of the terminal blocks and go with wiring option 1. I've quickly decided that's probably not a good idea because both ends are soldered and will not fit through the drag chain. I'll probably go back to terminal blocks as I get time. Luckily I left myself plenty of shielded wire.
I have a power supply, fan, e-stop button and other components on order for an electronics enclosure. I've already added the panel connectors, which you can see in one of the photos. Currently the electronics sit on my workbench with a fan pointed at them. Crude but it works. Hopefully the enclosure will come together in the next few weeks.
Before extended Y. Dust shoe, LED work lights, and Makita mounts
2014-01-26 20.54.55.jpg (340.9 KiB) Viewed 6287 times
Y extended to 1000mm with Mitsumi 80x20 and 40x20. Y rails doubled. Mechanical limit switches, connectors, and drag chain from Inventables. I haven't installed the 1000mm work lights yet.
2014-02-26 11.30.06.jpg (464.89 KiB) Viewed 6287 times
2014-02-26 11.30.30.jpg (356.13 KiB) Viewed 6287 times
Brian
Post by Brian » Wed Feb 26, 2014 9:01 pm
edwardrford wrote:All,
Can I email you pics and such? For some reason no matter how hard I try I can seem to upload pics on the forum, hah
Brian
Shapeoko 2 #I have no idea
samc99us
Post by samc99us » Wed Feb 26, 2014 9:02 pm
Will,
Do you have any more information on what is holding your zip-tied drag chain? Looks like an elegant solution and may be cheaper than real drag chain.
Edward:
Stock SO2
Dewalt DNP611 Router with Precise Bits Collet
ABS 3D Printer Router Mounts
Custom Acrylic Dust Shoe v1
T-nut work holding w/ 3D printed clamps (works like a champ!)
HobbyCNC Driver Board w/ LinuxCNC driver PC
Next week it'll be a 1000mm x 1500mm machine, rails are assembled but its time to move the carriages over (tonight) and re-wire the motors.
Best,
Sam
Post by edwardrford » Wed Feb 26, 2014 9:42 pm
Yes, feel free to email me directly. edward at shapeoko dot com.
Also, if you already have a wiki entry for your machine, go ahead and include the link so I can do some cross referencing.
Post by WillAdams » Wed Feb 26, 2014 9:47 pm
samc99us wrote: Do you have any more information on what is holding your zip-tied drag chain? Looks like an elegant solution and may be cheaper than real drag chain.
It's in the wiki: http://www.shapeoko.com/wiki/index.php/ ... a-Zip_Ties --- pretty straight-forward, though if I had it to do again, I'd flatten out the cable bundles and put zip ties around and in-between the wires.
More photos in this thread: http://www.shapeoko.com/forum/viewtopic ... =10#p12795
Post by Improbable Construct » Wed Feb 26, 2014 10:54 pm
Upgrades:
Painted Safety Red
NEMA 23 280 oz/in motors
Dual Drive
Alternate, Alternative Belt Drive Configuration
Carbon Fiber V4 motor plates
V2 end plates
Extended Y Axis 1200mm
Extended X Axis 1000mm
40x80 extrusion with hard coated openrail and steel wheels on X axis
18x25mm Drag Chain on X and Y Axis
Reversed Z-Axis, 20x80 extrusion with hard coated openrail and steel wheels
Custom 3/8" aluminum Z-Axis carriage and spindle mounts
Prototype 250mm 4 start ACME screw Z-Axis
DeWalt DWP611
Super P.I.D.
Prototype Improbable Construct Dust Shoe for DWP611
Dust Deputy Cyclonic Dust Collector
Custom Welded Table
Gecko Drive G540
48v Power Supply
Mach3 Control
http://www.shapeoko.com/wiki/index.php/ ... _Construct
