Pictures of finished machines
Damin69
Re: Pictures of finished machines
Post by Damin69 » Wed Mar 25, 2015 2:07 am
This is my ShapeOko 2 Modified. It is built out to a 1000mm x 1800mm.
Sub frame is made up of 20x40 extrusions.
I have beefed up the Y Axis Rails each side is a single 20x40 bolted to makerslide.
The Gantry has a 20x40 in the center with both pieces of makerslide bolted to it to make up a 60x40 gantry.
ACME Z Axis upgrade with Belt Drive.
Makita C0701 Trim Router.
I am running Nema 23 on all 3 axix
C-10 Breakout board
4 SainSmart 2M542 drivers
36V 10A PSU
12V PSU for Fans and LEDs
5V PSU for powering Breakout board
Keedox® CNC 3 Axis Electronic Wireless USB Handwheel Pulse Generator MPG Pendant
Bed is a 3/4" Birch ply topped with 3/4" MDF and 6 - 48" aluminum T-Tracks for clamping.
Running Mach3 as controller.
Shapeoko 2 #6971
Upgrades
Expanded to 1000 x 1800
Damin69's Build Log
Woodworker
Post by Woodworker » Wed Mar 25, 2015 2:47 am
Very nice. I'm just starting an 1800 x 1000 rebuild and there looks like several ideas there I can steal. Where did you get the cable chain?
Damin69
Post by Damin69 » Wed Mar 25, 2015 10:53 am
Drag chain from inventables.
Shapeoko 2 #6971
Upgrades
Damin69's Build Log
Woodworker
Post by Woodworker » Wed Mar 25, 2015 1:20 pm
Thank you.
