Sketchup 3d Models – Update 27th July 2012
Max Metz
New Sketchup Models - 12th June 2012
Post by Max Metz » Tue Jun 12, 2012 2:09 pm
These are the new Sketchup models, following in the vein of Edwards' latest models posted earlier this month on the Wiki as an aid to building the kit machine.
Each part is labelled with a part number and its source, then dimensioned; this information is accessible though turning on the dimension and part name layers. The dimension and part name label layers are off by default, to use them it is perhaps best practice to isolate the part required, hide the balance of the model, then with the selected part only visible - turn on the dimension and part name layers.
Aside from this each part name has the label information (part and source) included should you wish to delete the part name and dimension layers.
There are 14 models in the series, the last being the complete machine. This last complete Shapeoko model is also available with the dimension and part name layers removed for a smoother viewing and editing experience.
Again if anyone finds a mistake please post the same in this thread so it can be corrected and a new model version uploaded. Once any errors are ironed out the models can be pictured and linked on the Wiki.
Best regards. :D
http://sketchup.google.com/3dwarehouse/ ... 67ad6945df
MyBat Shapeoko 001 V Wheel Assembley.jpg (68.61 KiB) Viewed 2229 times
MyBat Shapeoko 002 Smooth Idler Assembly.jpg (68.2 KiB) Viewed 2229 times
MyBat Shapeoko 003 Y Axis Idle Plate Assembly.jpg (72.2 KiB) Viewed 2229 times
Max Metz
Re: Sketchup 3d Parts & Assembly Drawings – Update 12th Jun
Post by Max Metz » Tue Jun 12, 2012 2:12 pm
MyBat Shapeoko 004 Y Axis Motor Mount Plate Assembly.jpg (132.32 KiB) Viewed 2230 times
MyBat Shapeoko 005 X Axis Motor Mount Plate Assembly.jpg (109.52 KiB) Viewed 2230 times
MyBat Shapeoko 006 Z Axis Mount Plate Assembly.jpg (100.84 KiB) Viewed 2230 times
Max Metz
Post by Max Metz » Tue Jun 12, 2012 2:15 pm
MyBat Shapeoko 007 XZ Carriage Assembly.jpg (116.52 KiB) Viewed 2231 times
MyBat Shapeoko 008 Gantry Assembly.jpg (97.42 KiB) Viewed 2231 times
MyBat Shapeoko 009 Z Axis Spindle Mount.jpg (46.14 KiB) Viewed 2231 times
Max Metz
Post by Max Metz » Tue Jun 12, 2012 2:18 pm
MyBat Shapeoko 010 Spindle Mount Assembley.jpg (92.03 KiB) Viewed 2232 times
MyBat Shapeoko 011 Frame Assembley.jpg (108.96 KiB) Viewed 2232 times
MyBat Shapeoko 012 Frame & Gantry Assembley.jpg (127.59 KiB) Viewed 2232 times
Max Metz
Post by Max Metz » Tue Jun 12, 2012 2:22 pm
MyBat Shapeoko 013 Frame Gantry Z Axis Assembley.jpg (88.16 KiB) Viewed 2232 times
MyBat Shapeoko 014 Complete.jpg (105.65 KiB) Viewed 2232 times
MyBat Shapeoko 014 Complete Opaque without Labels and Dim.jpg (104.56 KiB) Viewed 2232 times
Glad that's done. :D
alpha
Re: Sketchup 3d Models – Update 12th Jun 2012
Post by alpha » Tue Jun 12, 2012 3:30 pm
Good job and thanks!
I'm sure you will be able to assemble your Shape in no time ;) probably with eyes closed :lol:
Max Metz
Post by Max Metz » Tue Jun 12, 2012 4:29 pm
lol and thanks Markus. :D
After ordering the Shapeoko full kit, a little haunted by the very low price to get into cnc, I decided that the best way to say a big hearty thanks to the Inventor and Community that made it possible was to contribute in some small way. This is it... lol
I have been using Sketchup for some years now for modelling concept designs, a mechanical drawing presented new challenges for me as all my revisions attest. Not usually a nitty gritty sort of chap, more a dreamer, the exercise had its moments and in the process I gained a better appreciation for drafts-persons.
I may do the same with the electronics. Thanks again mate. :D
Post by edwardrford » Tue Jun 12, 2012 4:52 pm
Onto the point that Markus was making: I found (still find) that modeling assemblies is a very nice way of "practicing" actually doing it in real life. For instance, by the time I received my ORDbot, I had been over the exploded views and STEP files enough times that I already knew what to expect and for the most part, what parts went where.
If nothing else, modeling is a good exercise to familiarize yourself with the assembly process. I'm guessing that because of the tremendous amount of work Max has put into the Sketchup models, assembly will be a breeze for him.
Max Metz
Post by Max Metz » Tue Jun 12, 2012 5:28 pm
Thanks Edward. :D
You are dead right about modelling stuff as way of familiarising oneself with what is involved in a concept, understanding and removing most of the vagueness is the key to capitalizing on most things. On first inspection the Shapeoko looks like a very simple solution to a complex task, drawing the machine revealed just how refined the solution was and that there are some very complex happenings in its construction that belie its relatively simple appearance.
The fact that it can be done mechanically for $200 plus a small freight charge (even worldwide) is extraordinary.
Now for the forbidding world of electronics, where I seek some solace in the fact that its open source and so I may not find myself so bewildered and lost - or at least will likely share the company of others who are similarly slowly moving forward after feeling uncomfortable initially.
It's blowing a gale here, two days ago it was at cyclone pitch, its looking like a very wet cold and windy winter - a far cry from the 42degC days and steamy nights of a few months back. I have never seen the Swan River so high - for someone who loves the winter its all a thrill. Good night all. :D
Max Metz
Post by Max Metz » Sat Jun 23, 2012 2:35 pm
New Shapeoko Sketchup 3D model with updated Motor Mount and Base plates available on Google 3D Warehouse. :D
MyBat Shapeoko with V2 X&Y Plates 001.jpg (106.3 KiB) Viewed 2189 times
