Scan a model from a real-world object?
flatline403
Post by flatline403 » Thu Jun 07, 2012 9:15 pm
I just ordered a ShapeOko kit in the last big order from Inventables. I'm new to CNCs, I've always just used a manual, hand-crank Mills.
Is there a way to "scan-in" a real-world object and create a model from that scan, so that the model can then be fed back into a ShapeOko to copy the original object?
It seems like a ShapeOko equipped with a number of sensors would be able to perform this task.
What is this sort of thing called, and has a method been established for hobbyists to do what I'm talking about?
Re: Scan a model from a real-world object?
Post by edwardrford » Thu Jun 07, 2012 9:22 pm
It's called a digitizing probe. Here's a video: http://www.youtube.com/watch?v=XJBpjddTfrA
This is where you set an object into the work envelope, then your machine moves in pre-definied increments going across in the X axis, then back in the Y slightly, then back across in the X. At each increment the Z-axis lowers until it runs into the object. While it's working, the program keeps track of the X/Y coordinated and the z-axis depth, essentially building a 3D model of points.
I've never used one, but have watched / read in extreme jealousy as others have built their own and used them. Would be a cool project to adapt to shapeoko. Here's one I've looked at before:http://www.brusselsprout.org/cnc/1p-probe/
flatline403
Post by flatline403 » Thu Jun 07, 2012 9:56 pm
Thanks Edward.
How much work do you think would be involved in adapting one of those for ShapeOko?
The SW side I'm sure is where the difficulty lies...
PLHS54
Post by PLHS54 » Thu Jun 07, 2012 10:30 pm
You can also take a look at http://www.david-laserscanner.com/ It's free too! *with some restraints, but will get you started
Max Metz
Reconstructme
Post by Max Metz » Fri Jun 08, 2012 1:16 am
Another approach seems to be using Microsoft Kinect (x-box) or Asus Xtion sensors under Microsoft Windows with the German software Reconstructme, looks impressive. http://reconstructme.net/
Recontructme appears to be free for non commercial use.
The software enables 3d scanning captures in real time, from a face to a car, scanning around an object or room produces a model in scalable 3d metric space. The model is then exportable to common 3d formats such as 3ds, obj or stl. Best regards. :D
DanMc
Post by DanMc » Fri Jun 08, 2012 10:36 am
Autodesk's new and free 123D also has a capture feature using a standard digital camera.
I've been using the David laser scanner. To get really good scans you need to put together a rotator for the laser and maybe a turntable, but now that you have a Shapeoko that shouldn't be a big deal :) I'm putting one together right now, if anyone is interested in the files I could post them.
flatline403
Post by flatline403 » Fri Jun 08, 2012 7:22 pm
Hey PLHS54,
Where do you see that the David Laserscanner is free? Everything I see on their site says it costs something like 600 Euros.
Right now I'm thinking the Kinect with Reconstructme is the most attractive option, but I suspect the David is more precise.
PLHS54
Post by PLHS54 » Sun Jun 10, 2012 7:27 pm
Here is the link, it should work. http://www.david-laserscanner.com/?section=Downloads It's the one at the top version 3.4.0.3008 Hope this helps
jrsteensen
Post by jrsteensen » Thu Jun 14, 2012 8:27 pm
David laser scanner software is free. You can use just about any quality web cam and just go down to the hardware store and buy the cheapest laser line/level they sell. Set up a couple pieces of plywood and Bobby is your uncle! I've used it quite a bit for complex CAD models.
dougal
Post by dougal » Tue Apr 15, 2014 4:03 pm
Hello all from Bristol, UK
At work we are using http://skanect.occipital.com/ for quick and dirty base mesh generation, i'm going to borrow an xbox kinect to clone some motorbike parts somewhen soon.
