Real world deflection - 1000mm
Post by Improbable Construct » Wed Jun 13, 2012 12:41 am
I got my heavily modified ShapeOko back together after lengthening the Y axis to 1000mm. I also doubled up the Makerslide on the X axis for stability.
http://www.shapeoko.com/forum/viewtopic.php?f=11&t=302
I put a dial indicator near the center of the span. (50mm away from center)
ShapeOko 037 (Large).jpg (62.69 KiB) Viewed 4214 times
I then ran the gantry to the center of the span.
ShapeOko 039 (Large).jpg (66.53 KiB) Viewed 4214 times
The deflection measured about .0065 inch.
When I moved the indicator to center and moved the gantry as close to it as i could get, it measured .007 inch.
I couldn't get a good angle for a picture for this one. :(
That is with the DeWalt DW660 mounted on the Z axis
I think I can work with that.
In metal it might be a problem, but in wood, it is way better than most of the other tools I have.
Comments?
DukeA42
Post by DukeA42 » Wed Jun 13, 2012 3:40 am
Did you brace the Y with any extra footing/support? I assume your X length is original length?
Re: Real world deflection - 1000mm
Post by Improbable Construct » Wed Jun 13, 2012 6:34 am
The Y axis is not braced in any way. No footings or other supports. The X axis is the original length, but it is doubled up.
CptanPanic
Post by CptanPanic » Wed Jun 13, 2012 11:51 am
Improbable Construct wrote:The Y axis is not braced in any way. No footings or other supports. The X axis is the original length, but it is doubled up.
You doubled the x axis to strengthen it rotationaly so you could put guide wheels on both sides?
