Plans Forward
g2ktcf
Plans Forward
Post by g2ktcf » Tue Apr 22, 2014 4:25 pm
Well, I am very good at buying lots of stuff and then never getting time to finish it. In fact, I know I have the serial number around here somewhere but cannot even find that right now! :shock:
I have both NEMA 17 and NEMA 23 motors and the original stock Shapeoko. I do plan on doing several of the upgrades but I want to get everything working first. Now all I need is a spindle. I saw one comment that the DW660 is too much for the stock unit. However, a Dremel to me is garbage and I really do not want to go this route (I have seen the inside of these things!). Noise is not an issue as I have a huge shop to "hide" everything in :D Eventually I will get one of the water cooled spindles but until then, IF I AM CAREFUL...will the DW660 be okay for the short term?
I have seen lots of comments about V2 and there is a lot to like but I have one unit already!!! lol
Re: Plans Forward
Post by WillAdams » Tue Apr 22, 2014 4:34 pm
Just implement the Dual MakerSlide X-axis upgrade and you should be good to go on a Dewalt DW660 --- for testing purposes, you could probably make a couple of cuts w/o doing any lasting damage, the problem is the weight of the unit as compared to a Dremel and the additional vibration I believe.
Will Winder
Re: Plans Forward
Post by Will Winder » Tue Apr 22, 2014 6:46 pm
I ran with a stock shapeoko and a DW660 for over a year, I've cut up to 1/4" aluminum in this way with no problems. Upgrading to dual extrusions will certainly help, but you can do just fine without it.
g2ktcf
Re: Plans Forward
Post by g2ktcf » Tue Apr 22, 2014 7:01 pm
Thanks Guys! I am actually working on a parts list now for the Dual Motor and Dual X Gantry now. I have noticed that this will not be a clean as "order the kit" though lol. I have NEMA 23 motors so I want to do that at the same time.
g2ktcf
Re: Plans Forward
Post by g2ktcf » Wed Apr 23, 2014 6:45 pm
Man, things cannot seem to go right. My new 142 oz-in NEMA 23 Stepper Motors have 6mm shafts!!! I cannot seem to find any GT2 pulleys for this shaft size. I leave an email with the folks at Stock Drive Components but does anyone else have any suggestions?
Re: Plans Forward
Post by edwardrford » Wed Apr 23, 2014 6:54 pm
Hi g2ktcf -
I'm not trying to talk down to you (honestly, i'm not).
It's very common for nema23 motors to have 1/4" shafts (6.35mm). If that's the case, then finding a 1/4" coupler should be very easy.
dcartier
Re: Plans Forward
Post by dcartier » Thu Apr 24, 2014 10:35 am
Hi g2ktcf,
I have been there, except from the other direction. I have some servo motors that I assumed had 1/4" (6.35mm) shafts and ordered expensive couplers only to find out the servos have 8mm shafts! To Edwards point, Nema 23 motors have 1/4" (6.35mm) shafts.
You can get affordable GT2 couplers from robotdigg.com. Their couplers are not the best quality, but they are all aluminim, and they are quite affordable. The last time I orderd anything from them I added 2 of every size of GT2 coupler they sell to my order in all shaft sizes from 5mm through 8mm, just so I would have a supply on hand incase I needed one.
Dennis
Gadgetman!
Re: Plans Forward
Post by Gadgetman! » Thu Apr 24, 2014 11:41 am
Actaully, NEMA motors can have a lot of different shafts.
NEMA 23 = Flange size of 2.3", nothing more.
It is more probably a NEMA 23D025, with the '25' part indicating a 1/4" shaft.
But that's only the DEFAULT shaft number.
A NEMA 23D020 is also a viable motor, and then it has a 0.2" shaft, which is close enough to 5mm that it makes no difference.
(NEMA 17 motors used in the ShapeOko or 3D printers are NEMA 17D020 )
http://classxboats.com/htdocs/Engineeri ... ics_16.pdf
(The interesting stuff is from page 48 and onwards)
Anyway, a 'NEMA 23' motor is bound to have a shaft that's some weird fraction of an inch, not a metric shaft.
And yeah, weirdly enough, a METRIC NEMA motor starts off with the shaft diameter instead of Flange size...
g2ktcf
Re: Plans Forward
Post by g2ktcf » Thu Apr 24, 2014 12:15 pm
I got these motors from here....
http://www.ebay.com/itm/121246818257?ss ... 1497.l2649
I have asked the seller about the pulley details but as of yet have no answer. I was just planning on removing them. Last night I realized that they are pressed on so I need to fashion a puller to remove them. I did take the motor apart and the quality of the motor is easily seen. I picked up 6 of these for $100. I figured that was pretty decent. The only downside was they are 200 steps/rev.
Re: Plans Forward
Post by edwardrford » Thu Apr 24, 2014 1:14 pm
Actually, my point was only that it is very common for nema23 motors to have 1/4" shafts. The vast majority of nema23 motors that I have interacted with have been 1/4" shafts but just as Gadgetman!' pointed out: the shaft size could be anything.
The shafts may very well be 6mm as the OP claimed. I just wanted to point out that it's common for the motors to have 1/4" shaft, and if it were indeed 6.35mm then finding a coupler to fit that should be very straight forward.
nothing more. nothing less.
