Calibrating for Ipê
Calibrating for Ipê
Post by WillAdams » Sat Jun 07, 2014 5:44 pm
Picked up 19 linear feet of Ipê at Bristol Valley Hardwoods in New York state (wonderful lumber yard --- highly recommended --- be sure to keep an eye out for Libby, the ``office manager'' she's wonderful) when I went to pick up my daughter from college --- gorgeous stuff, but incredibly hard / dense.
Cuts beautifully though. Decided to try the Precise Bits folk's technique: http://www.precisebits.com/tutorials/ca ... speeds.htm
and coded up a simple file:
Code: Select all
G17 G21 G90
G0 X0 Y0 Z3
G0 X6.35 Y3.175
G1 Z-3.175 F150 (20 percent of feed rate)
G1 X38.1 Y12.446 F750
G1 X6.35 Y21.717 F875
G1 X38.1 Y30.988 F1000
G1 X6.35 Y40.259 F1125
G1 X38.1 Y49.53 F1250
G1 X6.35 Y58.8 F1500
G1 X38.1 Y68.07 F1625
G1 X6.35 Y77.345 F1750
G0 Z3
G0 X0 Y0
which resulted in the following test cut:
So it looks like something a bit less than 750 is the hot ticket --- 562.5 or so --- now I just have to edit / update my file to match that.
and... it looks like climb cutting is best.
(This was on my SO1, w/ Harbor Freight 1/4" Trim Router and a Garr Tool Series 1/8"x3x1" bit at full speed (~26,000 R.P.M.)
Re: Calibrating for Ipê
Post by WillAdams » Sat Jun 07, 2014 10:50 pm
Well, everything that could go wrong did:
- one end of a belt came loose, then the other three ends of the Y-axis --- sequentially
- tripped the circuit breaker on the power strip 'cause I had the vacuum cleaner plugged into it
- didn't notice that the fan for the microcontroller didn't spin up, so lost steps on the last try
- managed to break a bit moving the gantry by hand trying to set up for another try
- vacuum cleaner overheated on the last run
- and finally workholding came loose on my last attempt, leading me to call it quits for the day
Other than that, cutting the stuff worked out fine, but I don't have anything worth showing.
Will probably just switch to trying to cut out a bow (I was trying to cut the circle-diamond-square test).
Tom Smith
Post by Tom Smith » Sat Jun 07, 2014 11:40 pm
Ouch. The universe is trying to tell you to do something else today, methinks :-)
Sent from my GT-P6810 using Tapatalk
_______________
ShapeOko1 191
Marty M.
Post by Marty M. » Wed Jun 11, 2014 4:23 pm
I live a couple miles down from Bristol Valley and made some deck post caps out of IPE work on my CNC .... That stuff is like working with steel. I still find the dust in the shed and it's been a couple years. Wear a dusk mask!
