Best bit for pin point fine line cutting?
games805
Post by games805 » Fri Jun 27, 2014 10:01 pm
I need a good solid pin point bit for fine line cutting. I have a DW660
suggestions?
ZachKaplan
Re: Best bit for pin point fine line cutting?
Post by ZachKaplan » Sat Jun 28, 2014 3:57 am
I use https://www.inventables.com/technologie ... piral-bits but they have an 1/8" shank.
These are more expensive but have a 1/4"
https://www.inventables.com/technologie ... -engraving
ralston4
Post by ralston4 » Sat Jun 28, 2014 4:04 am
Here's a bit that has 4 long flutes at 2.5" in length.
http://www.ebay.com/itm/TAPERED-TOOL-FO ... 1716&rt=nc
criznach
Post by criznach » Sat Jun 28, 2014 12:43 pm
I've been having fun with these...
http://www.ebay.com/itm/5-30-degree-ang ... 233522d655
If you use a v-carving software or plugin these bits can give you variable width from hair-line to 1/8". But for consistent width cutting, even maker cam would work.
