AtomCNC (GRBL Board)
Re: AtomCNC (GRBL Board)
Updated AtomCNC PDF! [DOWNLOAD]
Thank You! If i seem to be forgetting something just remind me. I look at the board every now and then and remind my self to add to the PDF
added links to the ShapeOko wiki:
http://www.shapeoko.com/wiki/index.php/ ... controller
@Atomsoft: Can you please let me know what kind of stepper motor you tested with your stepper driver?
ShapeOko uses 42BYGHM809 which has 1.68A current( given in datasheet). But I use 42BYGHM810 which has 2.4 A.
I use these: 42BYGHM809 which indeed is 1.7A (DATASHEET)jahn wrote:@Atomsoft: Can you please let me know what kind of stepper motor you tested with your stepper driver?
But the A4988 is said to be able to push 2A PER COIL... (INFO)
So as long as you limit it to the 2A using the POTs im sure you could use it but you wont get the full torque or something... im not a motor guy
I'm using this motor (nema17 from phidgets) and it seems to run fine when I set the A4988 to 2A like AS suggested.jahn wrote:But I use 42BYGHM810 which has 2.4 A.
Hi @AtomSoft »
I was able to work getting one of you're boards into my budget.
So I've signed up and contributed to the IndieGoGo.
I think this will benefit both of us, as I get what looks like a well constructed board and you get some cash flow.
I Launch Rockets, aka High Tech Welfare for Engineers
Your tax dollars have to go somewhere ... right!
ShapeOko S/N 396
Thanks RSWeaverAz! You ROCK! and welcome aboard! Ill start making your board first thing in the morning... takes me about 40-60 min to make
Also added you to: http://atomsofttech.com/AtomWiki/index. ... ntributors
Thanks for getting back to me with the USB type... have a look: (first USB TYPE B)
- Attachments
- typeb.jpg (50.81 KiB) Viewed 2393 times
