How do you cut your tabs?
danparker
Post by danparker » Mon Jul 07, 2014 3:57 am
Hi everyone!
I was using a dremel with a cut off disk to cut my work free, but lately I've been using just a plain jane set of side cutters.
Also, anyone had issues with Makercam only caring about the height of a tab and not the width? It seems like it doesn't account for the width of the bit when calculating the tabs. Or maybe. Or something.
Oh yeah, also, I love this machine.
criznach
Re: How do you cut your tabs?
Post by criznach » Mon Jul 07, 2014 5:04 pm
Depending on the material, I use either a snap-blade knife, x-acto, or a pair of flush wire cutters (some might consider that tool abuse). I use CamBam so I haven't done much with MakerCam tabs. Last time I looked they were a new feature that sort of worked, but that was a while ago. What options does it give you? When possible I do a test cut and adjust my tabs as small as possible so they're really easy to cut loose.
Woodworker
Post by Woodworker » Mon Jul 07, 2014 7:36 pm
It does not adjust the tab size for the diameter of the end mill, you have to do that in your head. They do work once you figure out what size to make them.
secretspy711
Post by secretspy711 » Mon Jul 07, 2014 7:47 pm
I'm a CNC noob but I've had great luck so far using triangular tabs in CamBam, .1" size. 3 tabs on a ~4" part and I'm able to easily snap it out with my hands, then just sandpaper or an exacto knife to shave them off the part.
Auarhau
Post by Auarhau » Mon Jul 07, 2014 11:18 pm
I use a small sharp chisel
akhlut
Post by akhlut » Tue Jul 08, 2014 12:25 am
Hacksaw blade
Ing Chao
Post by Ing Chao » Tue Jul 08, 2014 12:41 am
Flush cut pliers followed by a mini file for clean up.
glendresser
Post by glendresser » Tue Jul 08, 2014 2:07 am
Lots of different options work, as shown by the number of replies. I like a japanese keyhole saw.
