Getting a cleaner edge with HDPE?
tra
Post by tra » Sun Jul 13, 2014 2:46 pm
So I'm cutting 1/16" HDPE with a 1/8" two flute end mill and this is the edge I get. I've played with the spindle speed without much luck. Would cutting direction help? Faster or slower feed rate? This was at 20IPM.
http://i.imgur.com/9kwEQLd.jpg
Re: Getting a cleaner edge with HDPE?
Post by WillAdams » Sun Jul 13, 2014 2:54 pm
Here's what the wiki has: http://www.shapeoko.com/wiki/index.php/Materials#HDPE
A further note: "With HDPE you want to use conventional milling. It does leave a fuzzy, stringy edge when you use climb milling."
http://www.shapeoko.com/forum/viewtopic ... 17&p=15414
Slower spindle speed, faster feed and single flute bit should help.
I rub the pieces w/ a clean towel and take a swipe w/ a plane to clean up any edges which warrant it.
ZachKaplan
Post by ZachKaplan » Sun Jul 13, 2014 6:01 pm
We did some tests at Inventables and these settings worked successfully:
DIA = 0.0625
Step over% = 60
Step down = 0.045
Spindle Speed = 12,000
Feed Rate = 60
Plunge Rate = 30
DIA = 0.125
Step over% = 60
Step down = 0.062
Feed Rate = 60
Plunge Rate = 30
Woodworker
Post by Woodworker » Sun Jul 13, 2014 6:05 pm
You will have to secure the material differently but a down spiral bit should reduce the fuzzies. Since this is very thin, clearing the chips should not be an issue.
KevinB
Post by KevinB » Sat Jul 19, 2014 7:31 pm
are you using a spiral or straight 2 flute endmill?
I just recently cut some new spindle mounts out of HDPE and with straight 2 flute endmills.
My spiral mills left fuzzies.
Good luck
Kevin
"The Amount of equipment destroyed is directly proportional to the amount of information learned."
Shapeoko 2
tra
Post by tra » Sat Jul 19, 2014 8:43 pm
Thanks everyone. Cutting at 50+ ipm has left me with silky smooth edges.
