Upgraded to 9mm wide belts
Re: Upgraded to 9mm wide belts
Just a heads up for others, I ordered from this site:
http://www.sdp-si.com/eStore/Catalog/Pa ... -020DF0908
I shipped it to my apartment address, thinking I would get it before I moved out. Turns out, it came to my apartment after I had moved, so it was sent back to the company (sdp-spi.)
They contacted me asking why it had been shipped back. I explained the situation and gave them a different address. After that, I got no response and have not received my purchase. It's been over a month! I emailed two more times with no response; one back to the employee who contacted me and once to their generic "contact us" email address.
Moral of the story, get your shipping address right or don't deal with this company! I'm a little angry about it, since I may be out something like $50.
Any advice on how to deal with this sort of thing?
Have you checked with whoever is living at your old address now?
Maybe it ended up there again?
I found SDP/SI sales and customer service unresponsive too, but their products excellent. They never got back to me on several sales queries, both on the phone and via email.
If they said they would send it to your new address and didn't, and are not returning your calls, bring it up with your credit card company. I doubt they're doing it on purpose, but that still doesn't mean you should be out $50.
I had a forwarding address with the apartment office; though I'm not sure whether they would ship the package back (like they would if I was still living there) or forward it on.Gadgetman! wrote:Have you checked with whoever is living at your old address now?
To my surprise the package finally showed up yesterday! It's a bit frustrating, but at least it's here so I can finally install the idler pulleys and belts a receive quite awhile back.cvoinescu wrote:I found SDP/SI sales and customer service unresponsive too, but their products excellent. They never got back to me on several sales queries, both on the phone and via email.
As I was installing these belts last night, I started to wonder... do you have to retune the motors when switching to these belts? Or are all the dimensions the exact same (except width of the belt)?
If you had GT2 6mm wide and bought GT2 9mm wide, then the theoretical 2mm tooth spacing should stay the same.
That said, if you have a long axis, I suspect that you'll see less belt stretch and if you'd calibrated your machine so as to account for belt stretch ( http://www.shapeoko.com/wiki/index.php/ ... ting_Steps ) then you would probably want to re-do said calibration (and I suspect the number will be lower, closer to the ideally calculated value).
Awesome, thanks! I should have probably put two and two together on that oneWillAdams wrote:If you had GT2 6mm wide and bought GT2 9mm wide, then the theoretical 2mm tooth spacing should stay the same.
When I ordered my pulleys, I had no issues with them. I also didn't have anything come up where I needed to contact them.
I also recalibrated my machine when I put the new belts on. Anytime I do anything to the belts I check calibration. Cool to see how many people are upgrading their machines to 9mm belting.
Shapeoko 2 #3920. Nema 23's. Belt drive Z axis, ACME rod upgrade,
1m rails on X and Y, X upgraded to 60x40 extrusion with openrail, Mid span supports,
DW660 with Super-Pid, IC's DW660 dust shoe.
Build Log
Build Log
Sounds like, "Get it right the first time." Is a good solution, lol.groguard wrote:When I ordered my pulleys, I had no issues with them. I also didn't have anything come up where I needed to contact them.
Good to know, I guess I'll do a recalibration. It's pretty simple in Mach3, so why not?groguard wrote:I also recalibrated my machine when I put the new belts on. Anytime I do anything to the belts I check calibration.
I'm excited to see how they do. I have a little bit of backlash left after spending a decent amount of time making modifications, I'm hoping this will be my last major change for backlash.groguard wrote:Cool to see how many people are upgrading their machines to 9mm belting.
By the way, thanks for putting the information together!
I just realized the stock idlers are just barely not wide enough to fit a 9mm belt. Then I found the first post in this thread points to a wider idler at openbuildpartstore.
My question is: do I only need to order the plastic pulley and longer m5 screws? Or do I need the 5mm precision spacer also?
Basically, do I need to order the kit for $4.85 or can I just order the wider wheels?
Shapeoko2 #3702:
