red oak feed and speed
tsikows
Post by tsikows » Tue Sep 30, 2014 7:43 pm
hi all. i am currently making a coaster from red oak. i am having trouble getting my feed speed set decent. in the wiki it suggests a feed rate of 1000 mm/m with a depth of 1.5 mm. even at 600mm/m and 1mm cut it causes my steppers to miss steps and get way off track. is there something wrong with my machine operation or is the wiki page wrong?
Schruminator
Re: red oak feed and speed
Post by Schruminator » Tue Sep 30, 2014 7:56 pm
What spindle are you using? What endmill are you using?
I personally don't have experience with red oak, but I do know that the choice of endmill (1/4 vs 1/8, 1 flute vs 2 vs 3 flutes) and spindle (a Dremel is much different than a Dewalt DW611) will greatly affect whatever advice people may have.
Post by WillAdams » Tue Sep 30, 2014 8:23 pm
Please note that the suggested feed and speed were for a DW660:
as noted in the footnote: http://www.reddit.com/r/shapeoko/commen ... et/cguvh0r
I'm running a DeWalt DW660 ... It worked okay when I had the Nema17's, but I had to slow the z-axis acceleration way down or it would lose steps. (Was using a TinyG to drive the steppers)
Pine is no problem at all. IIRC, in red oak, I ran something like 1.5 mm depth passes at around 1000 mm/min with nema 17s.
tsikows
Post by tsikows » Tue Sep 30, 2014 9:36 pm
ok the more powerful spindle answers some of it but i guess i just answered my own question by replacing my first bit from inventable. i put on a brand new 4 flute bit and it honestly produces bigger chips than the dull 2 flute bit. i have now cranked the feed up to 750mm/m at a depth of 1mm with no issue what so ever. no more peeling either, just a beautiful clean cut. i guess just a little experience and common sense answers alot of questions.
Schruminator
Post by Schruminator » Tue Sep 30, 2014 9:46 pm
Careful with the 4 flute endmill. I purchased a few of them and I've had issues getting large enough chips. On wood with my DW611, a 2 flute seems to eat anything I put in front of it (well, except plastic-- 1 flute there), but my 4 flutes don't cut as well.
Woodworker
Post by Woodworker » Tue Sep 30, 2014 11:43 pm
I've been making coasters out of 6 mm ash and walnut. I have a 611 but like using a Down cutting spiral to reduce the curlies on the top side. I run about 1000 mm/sec and 1 to 1.5 mm doc. I could go faster but not on a stock machine, too much deflection in the arcs.
tsikows
Post by tsikows » Wed Oct 01, 2014 2:43 am
woodworker, how do you tell the difference between up and down cut? i do have minimal tearing at the edges but nothing the finish pass or light sanding cant handle.
Post by WillAdams » Wed Oct 01, 2014 11:05 am
We have a bit about up/down cut in the wiki: http://www.shapeoko.com/wiki/index.php/ ... _Cut_Types
lildave
Post by lildave » Thu Oct 02, 2014 1:25 am
I run a 660 1/8" 2 flute 1000mm 1.5m. A little stringy, but clean edge and no tear out. 1/4" Red oak coasters. Be careful it will cup if left in the sun.Image
