1/4 shank drill chuck and adapter
Caesar S
Post by Caesar S » Wed Oct 22, 2014 5:27 pm
It's really difficult working with collets with 1/4" shank diameter meant for router bits.
Is there such a thing as a drill chuck with a 1/4" round shank? It would be so much easier to use most diameters of end mill bits.
I've experimented with 6mm end mill bits and made it fit with a layer of electric tape around the 6mm shank. The electrical tape melted after 2 minutes though and the end mill bit came lose :lol:
I tried my hex drill bits and they don't fit in the 1/4" collet :roll:
Thanks, Caesar.
Gadgetman!
Re: 1/4 shank drill chuck and adapter
Post by Gadgetman! » Wed Oct 22, 2014 5:36 pm
What type of Collet are you using?
ER11(such as those used in the Quiet Cut), ER13 and other 'ER' collets comes in all sizes...
A 13-piece set of Metric ER11 collets with diameters from 1 to 7mm in 0.5mm increments isn't all that expensive, really.
Schruminator
Post by Schruminator » Wed Oct 22, 2014 5:38 pm
I'm not sure what you are looking for, but there are a plethora of endmills available in 1/4" shank diameter. I have single flutes, doubles flutes, 4-fluted, ball nose, square, 30 degree, 60 degree, 90 degree endmills and a half dozen different diameters (from 1/16" to 3/8"). On top of that, I picked up a 1/4" --> 1/8" adapter and I have another range of endmills that work flawlessly.
There are plenty of threads on here that point to good sources for enmills (drillman1 on eBay is a common one). If you have a common size you use that is not 1/4", look around for an adapter or for a custom collet that will fit your spindle. There are tons of options out there.
With regards to the drillchuck, that's a lot of mass to put on the end-- and at 1.5HP and 30,000 RPM I feel more confident with something I torqued down with a wrench. On top of that, I'm not aware of any endmills with hex shanks that are appropriate for the milling I do.
Caesar S
Post by Caesar S » Wed Oct 22, 2014 6:06 pm
Schruminator wrote:I'm not sure what you are looking for, but there are a plethora of endmills available in 1/4" shank diameter. I have single flutes, doubles flutes, 4-fluted, ball nose, square, 30 degree, 60 degree, 90 degree endmills and a half dozen different diameters (from 1/16" to 3/8")
These are exactly what I'm looking for!
Where did you purchase them from?
Thanks, Caesar.
Schruminator
Post by Schruminator » Wed Oct 22, 2014 6:10 pm
All of them off of eBay, and probably a bit over half of them from drillman1. He doesn't sell them as a kit (although I think there are some 1/8" ones bundled together), so I've just amassed them over the last year or so as the need arose. I think his shipping is flat rate, so you'll save money by buying more than one at a time if he has what you need.
The link below is a search of "1/4" in his eBay store.
http://www.ebay.ca/sch/m.html?_odkw=&_s ... 4&_sacat=0
Caesar S
Post by Caesar S » Wed Oct 22, 2014 6:14 pm
Gadgetman! wrote:What type of Collet are you using?
I'm using a 1/4 inch router. Makita RT0701C specifically. The ER11 collets work only with the Quiet Spindle. The Makita provides higher RPM (30,000) and torque for smoother cuts and/or faster feed rates (where the material allows it).
Schruminator
Post by Schruminator » Wed Oct 22, 2014 6:18 pm
Check, I believe there are a couple of companies out there that make custom or precision collets for your router. The stock collet on my DW611 performs well enough I haven't ordered one, but I know some people on this forum noted a marked improvement in runout with an aftermarket collet.
Caesar S
Post by Caesar S » Wed Oct 22, 2014 8:31 pm
Thanks! I found this custom collet maker (from WillAdams post) http://www.elairecorp.com/makitaroutercollets.html. They carry various collet sizes online specific to Makita RT0701C $24.50 each.
I purchased the 1/8th and 6mm collets. There area also 8mm collets. Sets of SAE and metric collets as well.
Post by edwardrford » Wed Oct 22, 2014 8:38 pm
You might want to check with PreciseBits about your model. They specialize in this sort of thing (if I'm understanding your question correctly!).
I can vouch for them to provide high quality products and great service. Plus, I think they're on this forum as well (not advertising, but as members) - They have appeared to be generally helpful and non-intrusive, which probably explains why they didn't answer this thread directly. Or maybe they dont' make their kit for the Makita RT0701C?
http://www.precisebits.com/
Caesar S
Post by Caesar S » Wed Oct 22, 2014 8:42 pm
Hi Edward,
It's nice to see you!
I checked out their collet page http://www.precisebits.com/gateways/ColletsNutsHome.htm
They don't have Makita on their list. I'll ask if they carry it somehow.
Thanks! Caesar.
