ACME screw bearing size
H in OH
Post by H in OH » Tue Oct 28, 2014 4:37 am
What is the outer diameter for the flange bearings (not counting the flanges) intended for the SO2 3/8" Acme screw mounting kits? I ask while thinking about using a larger diameter screw to lift a heavier load in the Z axis.
Thanks,
---H
crazeegeek
Re: ACME screw bearing size
Post by crazeegeek » Tue Oct 28, 2014 10:06 am
It uses the same flanged bearing(F608-ZZ) as the stock SO2, which has a 22mm OD.
H in OH
Post by H in OH » Sun Nov 02, 2014 4:10 am
crazeegeek wrote:It uses the same flanged bearing(F608-ZZ) as the stock SO2, which has a 22mm OD.
So the ACME screw must have its leads ground to an 8mm diameter. How far is the lead ground down on both sides?
Thanks,
---H
Improbable Construct
Post by Improbable Construct » Sun Nov 02, 2014 1:18 pm
The screw is turned down to 7.92 mm diameter to fit into the bearing. One end has 7 mm turned down along its length the other end has 30 mm turned down.
H in OH
Post by H in OH » Sun Nov 09, 2014 12:11 am
It looks like there is a fair amount of front-to-back adjustment in the bearing mounting plate design. Is there enough for clearance of a 1/2 inch screw and nut instead of a 3/8 screw? The best way to tell is probably what is the maximum clearance from the edge of the rail to the center of the screw/bearing if the bearing plate is as far out as the mounting screws will allow?
Thanks.
---H
Post by Improbable Construct » Sun Nov 09, 2014 1:05 am
There is 9mm from the edge of the makerslide to the center of the hole in the plate when it is fully extended. A 1/2" acme screw is ~12.7mm. Half of that is ~6.35mm. That would give you 2.65mm of room for the wall of the nut. So, yes it should be possible but the question is why would you need/want to do it. :)
H in OH
Post by H in OH » Sun Nov 09, 2014 6:24 pm
Improbable Construct wrote: So, yes it should be possible but the question is why would you need/want to do it. :)
Keeping options open since I want to lift about 20lbs. up a 34in. long slide track. Not sure if a 3/8 screw can handle the weight or avoid deflecting in that distance.
