Questions about Shapeoko 2
A1art
Post by A1art » Tue Nov 25, 2014 2:37 am
Hi all,
Im wondering if the Shapeoko 2 complete upgraded kit is the right choice for my first cnc machine and have a few questions.
1: Do these machines use lots of electricity? Any estimated cost per hour of use?
2: Do you need a newer or certain type of PC/laptop to install the mach 3 software or other programs? Any suggestions on an affordable computer to use just for the Shapeoko 2 machine?
3: Will the Shapeoko 2 hold up for 14 hour runs continuously one after another. I need to make a few dozen parts that take about 14 hours each finish. Will the machine handle the wear and tear?
Thanks in advance! looking forward to hopefully owning a Shapeoko 2
Re: Questions about Shapeoko 2
Post by WillAdams » Tue Nov 25, 2014 2:53 am
I don't believe the electric usage is excessive (this may be dependent on your choice of spindle).
Pretty much any machine w/ a USB port will work --- I use an ancient Tablet PC (Fujitsu Stylistic ST-4110)
Long runs have been done, but require a bit of setup and testing first --- I'd certainly recommend limit switches, and I'm curious if the wider belt upgrades would help w/ this sort of thing.
Luxx
Post by Luxx » Tue Nov 25, 2014 3:58 am
for long runs I would recommend good cooling on your driver boards, and possible cooling on your stepper motors, as well as a descent spindle that you will be comfortable with running for that long.
Shapeoko2 #3529 - DW660, Nema23 X+Y, Reinforced wasteboard.
cozmicray
Post by cozmicray » Tue Nov 25, 2014 6:18 am
What machine required 14 hours for job?
A high speed rotary spindle running for 14 hours
is the problem.
I don't think the dremel like Altocraft spindle will handle it.
Perhaps a water cooled VFD spindle about
the cost of a Shapeoko 2 kit would be required.
Thousands of Kwh.
All the fasteners on Shapeoko locked with lock washers
and thread locker.
A track / bolt down clamping system
http://www.rockler.com/auto-lock-t-track-clamp
http://www.bestwoodworkingrouters.com/C ... amps.shtml
Post by WillAdams » Tue Nov 25, 2014 11:15 am
I ran my Dremel 4000 for about 7 hours, more-or-less continuously. Aside from the bit coming loose once, things went fine --- the noise was a big impetus for upgrading the spindle though.
