Do you see a problem with this GCode?
metalli445
Post by metalli445 » Sun Dec 21, 2014 12:42 am
I was in the middle of a cut when all of a sudden the CNC stopped. The time kept running but the line count never increased. I captured the lines when it worked fine until it stopped working. I don't see anything abnormal that would cause it to stop responding. Any ideas? The gcode is posted below. Thanks
G1X22.4716Y28.6672 true true ok
G1X22.3837Y28.6497 true true ok
G1X22.2969Y28.6271 true true ok
G1X22.2113Y28.5994 true true ok
G1X22.1275Y28.5671 true true ok
G1X22.0457Y28.5303 true true ok
G1X21.9662Y28.4886 true true ok
G1X21.8890Y28.4427 true true ok
G1X21.8145Y28.3924 true true ok
G1X21.7432Y28.3380 true false
G1X21.6748Y28.2799 true false
G1X21.6101Y28.2176 true false
G1X21.5486Y28.1521 true false
G1X21.4912Y28.0830 true false
G1X21.4379Y28.0109 true false
G1X21.3886Y27.9357 false false
G1X21.3436Y27.8580 false false
Shapeoko 2 Mechanical Kit - NEMA 23- X and Y axis, NEMA 17-Z axis, Acme Upgrade, DW660 with mounts. Arduino-gShield with .9i loaded
tbfleming
Re: Do you see a problem with this GCode?
Post by tbfleming » Sun Dec 21, 2014 2:45 pm
Which controller are you using? What happens if you strip away all gcode except these lines?
Gadgetman!
Post by Gadgetman! » Sun Dec 21, 2014 2:54 pm
How long is the job?
How long does it run before stopping?
Do you have any active cooling on the controller?
metalli445
Post by metalli445 » Tue Dec 23, 2014 4:32 am
So I just wanted to update the thread. Since posting my issue I've ran the file 4 times and it has worked every time. I'm not quite sure why it stopped working the first time I ran it but it's been good ever since.
