eShapeoko recomented microsteps and steps/mm for accuracy
Georgei
Post by Georgei » Sun Jan 25, 2015 2:10 pm
Hi everyone,
My motors are Nema17 (high torque) and they have 1.8 degrees step (200 steps/ rev).
The controller I am using can go up to 1/16th micro-stepping.
The belt in x,y is MXL with a pitch of 0.08" or 2.032mm and 18teeth pulleys.
In z is a TR8x2 lead screw with 2mm/rev pitch.
Can anyone suggest what micro-stepping and steps/unit (in my case steps/mm) will give the best performance for high accuracy (inlays).
Any suggestion are welcome.
George
akhlut
Re: eShapeoko recomented microsteps and steps/mm for accurac
Post by akhlut » Sun Jan 25, 2015 2:37 pm
If your steppers are rated at 5%, then 1/8 step. Anything above this is phantom resolution.
43.788 for X and Y
800 for Z
http://nathan7.eu/stuff/RepRapCalculato ... rStuffSPMB
Georgei
Post by Georgei » Sun Jan 25, 2015 3:43 pm
akhlut wrote:If your steppers are rated at 5%
I suppose the 5% is the error of the motors. Is this percent per revolution or per 1.8 degrees step?
George
akhlut
Post by akhlut » Sun Jan 25, 2015 6:22 pm
A step motor is a mechanical device that is manufactured to a certain tolerance. Typically a standard motor has a tolerance of +/- 5% non accumulative error regarding the location of any given step. This means that any step on a typical 200 step per revolution motor will be within a 0.18-degree error range. Stated otherwise, the motor can accurately resolve 2000 radial locations.
Source
Georgei
Post by Georgei » Sun Jan 25, 2015 9:04 pm
That is exactly the settings I have right now.
What will be the recommended max values for velocity and acceleration for these values?
George
Gadgetman!
Post by Gadgetman! » Sun Jan 25, 2015 9:22 pm
That depends entirely on the stiffness of your machine and the components you've used...
Can you list what you have, possibly with a picture if you've done something not entirely stock, and possibly what kind of accuracy you're getting now?
(with feeds and speeds, material, endmill and all that)
Georgei
Post by Georgei » Sun Jan 25, 2015 9:38 pm
The machine will be an eShapeoko 500x500 with double rail on the x axis.
Obviously I haven't got the machine yet but I am setting up all the electronics (programs settings motors etc).
The machine will be used mostly for engraving and for inlays (luthiers inlays) in hard wood.
I am not looking for the feed rates for cutting but for the maximum safe speed for rapids (if the term is correct meaning moving fast without cutting).
George
