Recommendation for aluminum cutting bits?
Caesar S
Post by Caesar S » Wed Feb 11, 2015 8:57 pm
Hi there,
I'm drilling M6 holes in aluminum 9x9 in 3/8 thick.
There are 40 M6 holes, will be drilled in ShapeOko 2 A
After the holes are drilled, the 9x9 plates are cut out in ShapeOko 2 B
I plan on fastening the aluminum sheet (30 x 30 in) by screwing it into the wasteboard, or using t-slot clamps (from holes in the middle).
What bit(s) would you recommend that can withstand the production volume of say 4 30x30 inch plates in a day?
Since this is a production run, I'd like to have good quality, very low runout, last for a long time (yes with lubrication).
Thank You! Caesar.
