How to increase Shapeoko2 speed (movement speed)
mano
Post by mano » Mon Mar 02, 2015 3:53 pm
Good afternoon guys,
I'm wasting to much time looking at the machine while it moves from a point to another when it is not cutting...Do you know how I can change that? I know how to increase the catting spped (aka feedrate) but not the general speed of the machine when it's not cutting...The software i'm it's using Autocad > Meshcam > Universal Gcode sender.
Thank you in advance.
Andre Mano
fl0yd
Re: How to increase Shapeoko2 speed (movement speed)
Post by fl0yd » Mon Mar 02, 2015 4:09 pm
mano wrote:Good afternoon guys,
Andre Mano
  • What controller are you using? Tinyg, GRBLshield, Something else?
  • What firmware version for the above controller?
Fl0yd
Post by cvoinescu » Mon Mar 02, 2015 4:43 pm
If you're using GRBL, the traverse (aka seek, aka rapid) speed is controlled by GRBL settings, not by the CAM program. Acceleration can also make a huge difference, so it's worth tuning too.
Check out https://github.com/grbl/grbl/wiki/Configuring-Grbl-v0.9 -- the relevant parameters are $110..112 and $120..122. (If you have GRBL 0.8, I strongly suggest you upgrade to 0.9, unless you use Easel. 0.9 can move significantly faster than 0.8.)
mano
Post by mano » Tue Mar 03, 2015 10:05 am
Thank you very much for your quick answers.
I understood what you told me but I can't find or edit $120, $121 or $122.... Those values don't even show up on my Gcode Universal Sender (version 1.0.7) and nothing happens if i press $x. I've changed already $4, $5 and $8 and I'll see what happens. I'll attach a picture of what my Gcode Sender $$ menu.
Gadgetman!
Post by Gadgetman! » Tue Mar 03, 2015 10:41 am
It looks like you have GRBL 0.8something on your Arduino.
It's HIGHLY recommended to upgrade to 0.9 unless you use Easel.
(See the link cvoinescu posted)
mano
Post by mano » Tue Mar 03, 2015 11:08 am
After a struggle I was able to update to V0.9 and everything is working as I wanted. Thank a lot guys :)
sunnamp33
Post by sunnamp33 » Tue Mar 03, 2015 5:39 pm
I am also using GRBL 0.8. I haven't upgraded yet because I finally got it dialed in. Will have to start over if I upgrade? Sorry to hijack but I have the same speed question and it looks like you got the answer I needed. Thank you for your time.
Gadgetman!
Post by Gadgetman! » Tue Mar 03, 2015 8:12 pm
Write down your settings, because the upgrade will delete them.
Then it's a minute or two to load them back(they've changes numbers, though. Read the Wiki for details).
so easy that even I could do it...
Chrisprols
Post by Chrisprols » Wed Mar 04, 2015 12:57 pm
a link that might be usefull to people reading thie thread :
http://www.shapeoko.com/wiki/index.php/Grbl#Upgrading
Shapeoko 2 #4852 with Bosch Colt
