How to prepare for Shapeoko 3 - New to CNC
Re: How to prepare for Shapeoko 3 - New to CNC
What would be the typical computer specs needed to run the programs of Shapeoko3?
As I am also preparing to assemble my newly arrived Shapeoko3, I noticed some
problems after just examining how the parts are to be assembled.
1. I received one short belt which is endless and 2 long belts which are cut off. Are they supposed to be cut?
2. Item #26 on the x axis are tapped for 4 mm and there is no 4 mm screws on the parts. Can retap it myself.
3. My other concern is the pulley on the Z axis which is installed with a screw and a bolt on the other side of the
plate. Looks like there is a possibility that the bolt will unlock when the pulley starts turning.
4. Without checking I just installed the motors and is now wondering if Y motors are different for
X and Z motors.
5. ON pulley installation would it be correct if I just push it in flush with the end of the shaft
or does it need to go in further?
These are my concerns as I assemble my Shapeoko 3. Your expert comments will be highly valued.
Thanks, one and all! These are exciting times.
X and Z motors.
1. Correct. Endless is for Z, there should be enough additional belting for X (1 x 800mm) and Y (2 x 800mm) see http://www.shapeoko.com/wiki/index.php/Shapeoko_3#Belts
2. Part number?
3. Mine hasn’t. This would be a good place to use the lock Tite
4. Yes, X and Z have one length leads, Y has the other: http://www.shapeoko.com/wiki/index.php/Shapeoko_3#S3103
5. Yes, save that the X-axis is reversed. http://www.shapeoko.com/wiki/index.php/ ... lConstruct
Did you see the latest version of the assembly instructions? Current version is published from the main shapeoko.com page.
2. Part number?
That pulley does not turn. It is used as a belt grip, not as a proper pulley.Got2tinxxer wrote:3. My other concern is the pulley on the Z axis which is installed with a screw and a bolt on the other side of the
Not sure if anyone is in the market for DWP611.
Ordering my Shapeoko today, I found Home Depot is having a Dewalt promotion.
Promotion Details
Price Valid : 11/16/2015 - 12/23/2015
$25 off $100 purchase of select DEWALT items.
Cart Price is $91.70 which is the lowest I have found
Promotion Details
This is first thing I just did.
You can see my XL sitting inside and below ready for assembles..
That’s next
Lol. Than crash course CNC. Then baby steps..
That’s next
- Attachments
- D4D7CE39-01FB-4861-823F-FE8B22A319F0.jpeg (67.55 KiB) Viewed 9842 times
- BCB43F70-ECE2-4F10-93E7-1A32505A8C28.jpeg (108.27 KiB) Viewed 9842 times
- 22A4305B-443E-4A2A-8723-41B0164F95D5.jpeg (103.15 KiB) Viewed 9842 times
Me too compressing and uncompress files in command prompt by using 7zip tool...WillAdams wrote:The most reliable unzipping tool I've used in 7Zip: http://www.7-zip.org/
If you could provide the names of the tools you're having difficulty w/ we can look into them.
7-zip.org and 7zipguides. Aren't they the same? Owner of Cameengo, I published several reviews about portable butane torch and portable travel crib for babies.kiana1990 wrote: ↑Wed Feb 20, 2019 5:44 amMe too compressing and uncompress files in command prompt by using 7zip tool...WillAdams wrote:The most reliable unzipping tool I've used in 7Zip: http://www.7-zip.org/
I knew I made the right decision when I bought this machine.
Thanks for your patience and all your help Will.
