Upgrading my Y Axis to 1000mm...
bharbour
Post by bharbour » Fri May 15, 2015 7:13 pm
I'm trying to get up a BOM for upgrading my Y axis to 1000mm. Obviously I'll need (from Inventables) 2 X 26049-02 (20mm extrusion), and 2 X 25142-03 (Makerslide). Exactly how much belting should I get for the longer extrusion?
Also...what will I need for wire to go back to the controller for the motors? I will also get the mid-span supports. Am I missing anything? Or maybe you could share your BOM with me if you've done the upgrade...thanks,
Re: Upgrading my Y Axis to 1000mm...
Post by WillAdams » Fri May 15, 2015 7:29 pm
As I recall, I put various notes from mine (for my SO1) on the wiki:
http://www.shapeoko.com/wiki/index.php/ ... lt_Lengths
1M Dual-drive (1-axis, two pairs of belts) 7 ft. will work, if belt anchoring is efficient --- 8ft. has length to spare
For wire, I found it most expedient to just buy long lengths of wire, run from the coiled wire, then cut when the run was complete --- I think Inventables has a figure for their 1Mx1M kit --- use 2/3rds of that length?
bharbour
Post by bharbour » Fri May 15, 2015 7:46 pm
I just realized that I won't need the 20mm extrusions if I'm only upgrading the Y axis. I can use the existing extrusions as the X will be the same width for now.
EDIT...maybe one 20mm extrusion to run down the center of the wasteboard...
UnequalTech
Post by UnequalTech » Sat May 16, 2015 10:29 pm
What spindle do you have? I get quite a bit of deflection with my Makita even with 2 20x1000 extrusions under y-axis makerslide. Guess it depends on your bed. Definitely recommend mid span supports. Image
Shapeoko 2 #?? w/Makita RT 0701C
bharbour
Post by bharbour » Mon May 18, 2015 2:19 am
I have the Makita,too. Yea...mid span supports for sure!!
UnequalTech wrote:What spindle do you have? I get quite a bit of deflection with my Makita even with 2 20x1000 extrusions under y-axis makerslide. Guess it depends on your bed. Definitely recommend mid span supports. Image
