Hardwood on Shapeoko 3?
estes53
Post by estes53 » Tue Jul 14, 2015 8:38 pm
Can anyone attest to the Shapeoko 3's ability to cut hardwood?
Thanx, Alan
Re: Hardwood on Shapeoko 3?
Post by WillAdams » Tue Jul 14, 2015 9:06 pm
The ShapeOko 1 could cut Ipê fine, so the SO3 should manage pretty much any hardwood w/ aplomb.
LTEPM
Post by LTEPM » Wed Jul 15, 2015 12:20 am
I have used mine for alder, ash,maple, sassafras, purpleheart, padauk, cherry, walnut, and it works well, have cut up to 1 1/4" thick stock. You do need to adjust feed rate, speed, and depth of cut depending upon which hardwood you are cutting.
Takes a little trial and error to find the sweet spot.
JeromyReno
Post by JeromyReno » Wed Jul 15, 2015 4:46 pm
mine rips threw red oak like a charm .1875 two flute,50 ipm %45 step over .1875 depth, full depth passes other than the border was .1" passes at 30ipm
garetbiglow
Post by garetbiglow » Thu Jul 16, 2015 12:53 am
Can you post an image/link of the end mill? Is that a straight two flute end mill? The edges look pretty clean (which makes me think it was a straight flute). Also what was you dewalt set to for speed? I'm trying to get a good source of end mills sorted out for exactly this type of cutting.
SO3 #0196
JeromyReno
Post by JeromyReno » Thu Jul 16, 2015 4:02 pm
of course, http://www.lakeshorecarbide.com/316carb ... gth-1.aspx , I have a super high precision collet too from precisebits.com http://www.precisebits.com/products/equ ... it!!!PG!!!
run at the highest speed the router will run at. I did hit the edges lightly with one of those foam sanding blocks with 500 or 600 grit. they where pretty smooth already, it was just to keep from splintering
Post by edwardrford » Thu Jul 16, 2015 8:29 pm
@JeremyReno - thanks for the photos, those signs look great.
I posted a link to twitter: https://twitter.com/shapeoko/status/621778353964613632
JeromyReno
Post by JeromyReno » Mon Jul 20, 2015 2:46 pm
awesome! im glad you like them : )
