SO3 Control Box
wunderaa
SO3 Control Box
Post by wunderaa » Fri Aug 07, 2015 10:01 pm
Thought I'd throw this out there. I slapped together a control box for my unit this week. Inside of here, I've got start/stop buttons for spindle and dust collector through relays, the 24V supply, e-stop. Future add-ons will include signaling for touch plate, e-stop input to Carbide 3D board, feed hold, spindle enable from the carbide board. Wiring isn't so pretty, since it's what I had on hand. Functional though! If there's a desire for part info, just let me know.
Regards,
Aaron
TomDChi
Re: SO3 Control Box
Post by TomDChi » Sat Aug 08, 2015 1:02 am
Very interesting! A couple of noob questions:
What is a source/part number for that enclosure?
I think I get the basic idea for switch --> relay --> AC powered system (spindle, dust control, etc), but I don't know enough to figure out what those parts are that work together. Again, if you wouldn't mid, what are those parts? Thanks!
jayftee
Re: SO3 Control Box
Post by jayftee » Sat Aug 08, 2015 9:30 pm
wunderaa wrote:Thought I'd throw this out there. I slapped together a control box for my unit this week. Inside of here, I've got start/stop buttons for spindle and dust collector through relays, the 24V supply, e-stop. Future add-ons will include signaling for touch plate, e-stop input to Carbide 3D board, feed hold, spindle enable from the carbide board. Wiring isn't so pretty, since it's what I had on hand. Functional though! If there's a desire for part info, just let me know.
Regards,
Aaron
Quite nice. I started with a box (3D Printed) for my Super-PID, and will move on making a second box as controller box for the dust, e-stop, and the like, but I am a noob at electronics, so it will take time. Yours box looks better than mine, however.
I have XTC-3D on order, and will use that to seal my box, and give it a nice factory finish (I hope).
Jeff
wunderaa
Re: SO3 Control Box
Post by wunderaa » Sun Aug 09, 2015 3:50 pm
Jeff, looking great. With that top coat, it will be very sweet indeed!
wunderaa
Re: SO3 Control Box
Post by wunderaa » Sun Aug 09, 2015 5:02 pm
Here's a point-to-point look at the wiring for my box. Once the spindle-enable signal is picked up from the Carbide 3D board, that signal will be connected to switch 2's common ("C") terminal.
Control Box Wiring_PTP.png (29.19 KiB) Viewed 2832 times
jayftee
Re: SO3 Control Box
Post by jayftee » Sun Aug 09, 2015 10:20 pm
Wonderful.
That shall get me started in the right direction.
Thank you very much.
Jeff
TomDChi
Re: SO3 Control Box
Post by TomDChi » Mon Aug 10, 2015 5:21 pm
Fantastic! Thanks for the parts list and the diagram!
One noob question - clearly it's "obvious" what relays those are... but not to me! What model or specs are those relays? Are they mounted on that rail?
Thanks very much!
wunderaa
Re: SO3 Control Box
Post by wunderaa » Tue Aug 11, 2015 3:02 am
So sorry, looks like the relay and base didn't make the list! Again there are cheaper options than what I list here. You will be looking for a 24v DC 10A 8 pin relay and base.
http://www.mouser.com/Search/m_ProductD ... AgwT8P8HAQ
[/url]http://www.mouser.com/Search/m_ProductD ... AlKa8P8HAQ[/url]
TomDChi
Re: SO3 Control Box
Post by TomDChi » Tue Aug 11, 2015 8:34 pm
Thanks again! I've been researching the components like the relays and tracing out how you set everything up. Turns out relays are as straight forward as I thought!
