Another Dial Indicator Bracket
Seemed like a good spot for a dial indicator bracket. So far so good.
- Attachments
- 0909151250.jpg (105.92 KiB) Viewed 5431 times
- 0909151249.jpg (113.4 KiB) Viewed 5431 times
Re: Another Dial Indicator Bracket
Oh, I like that... Thanks for the idea.
It would be nice if we could all standardize on a location and sizes/threads for these holes --- maybe then we could work up some synergy w/ mounting brackets &c.
Attached is some CAD data if anyone is interested (step and stl). I actually used a 3D printed version for a bit. It works just as well but cutting one out in 1/2" thick aluminum on the Shapeoko is sexier looking. Matches the mount anyway. Prototyped one out of wood too. Wooden one will work but you have to be mindful of the grain direction. The holes are for 1/4"-20 fasteners. Obviously, the center hole is the only one that needs to be tapped.
- Attachments
- CAD.zip
- (36.25 KiB) Downloaded 60 times
- Stuffs.jpg (213.84 KiB) Viewed 5391 times
Good idea, nice execution. Has a stock look to it. I might go for a brass- or plastic-tipped set screw to avoid marring the indicator shaft.
Shapeoko #1,123
Thanks for the files. I was thinking about CADing one up to 3D print. Now I don't have to.
Silly question, do mill with that on? Or remove it?
heathenx wrote:Seemed like a good spot for a dial indicator bracket. So far so good.
-- sraney
- break nothing but silence
- take nothing but pictures
- leave nothing but footprints
You should be able to leave the bracket on while you mill. If you put it on the front like the photo shows.sraney wrote:Silly question, do mill with that on? Or remove it?
I would not leave the indicator attached though.
You could make a swivel version, so it always stays on the machine. Ball detent maybe. Repeatable enough in Z.
Shapeoko #1,123
No, I do not mill with the dial indicator installed.
