SO3 Gantry Stiffness in Y direction
TomDChi
Re: SO3 Gantry Stiffness in Y direction
Post by TomDChi » Wed Sep 23, 2015 6:43 pm
MikeD wrote:Andrew,
Did you have to edit the post processor to get F360 to output code that was useable right away? I generated some code, but to get it to run I had to go put a J0 every line that there was an I and no J. Pretty cool software, very easy to use otherwise.
I found this video of some one hauling ass on an SO2... https://www.youtube.com/watch?v=85C88YrdhHg
-Mike
Mike - I was doing that too, but the only issue is with the Carbide software choking on the lack of J0/I0, etc. Using the same code with Universal G Code Sender or ChiliPeppr works perfectly well for me.
I guess I'll try the new Carbide3D post processor from Fusion with Carbide's software to see if it works that way.
jkanzaki
Post by jkanzaki » Tue Dec 22, 2015 8:17 pm
Hey Guys,
I've been following this thread on how to stiffen up the z axis plate. There is a question I have about space clearance?
I've attached a picture with annotation to my concern. The gap between the z axis plate and the aluminum railing for the z axis v wheel is very small how do you guy manage to put a nut behind there ?
or
Do you counter sink a hole from the back and use a flat head screw?
thanks
Henry
Shapeoko 1 - dissassemble
jkanzaki
Post by jkanzaki » Tue Dec 22, 2015 8:19 pm
not sure how to upload two image but theres the other configuration if I add a nut behind the plate to secure the aluminum plate, I find the gap is too small.
jkanzaki wrote:Hey Guys,
or
thanks
Henry
Fablicator
Post by Fablicator » Tue Dec 22, 2015 8:59 pm
I drilled and tapped the steel.
Post by twforeman » Tue Dec 22, 2015 9:04 pm
I just did a mod like this (haven't written it up yet) and I bought flat head cap screws and countersunk them into the back of the plate.
LTEPM
Post by LTEPM » Wed Dec 23, 2015 4:30 am
I drilled and tapped the steel plate. Wasn't sure if the screws would work loose and bind against the extrusions for thru-bolting.
So far the screws tapped into the steel have not worked loose.
