My work hold in progress for S3
designxtek
Post by designxtek » Wed Sep 30, 2015 6:00 am
Started drilling holes in my MDF wasteboard.
Added T Nuts.
2015-09-29 22.41.01.jpg (81.65 KiB) Viewed 2571 times
2015-09-29 22.41.23.jpg (124.16 KiB) Viewed 2571 times
I accidentally hammered one of the T Nuts too hard and it made my MDF warp a little around the area. :(
Hopefully it won't affect my work holding too much once I get the mounts done.
I will definitely get the aluminum threaded surface when Carbide3D comes out with it. I think the MDF will eventually warp over time.
Gadgetman!
Re: My work hold in progress for S3
Post by Gadgetman! » Wed Sep 30, 2015 7:26 am
If it warps you used too thin MDF...
I used the same type of nuts and 15mm plywood for my first wasteboard.
Now I'm using the type you screw in, and 22mm Plywood.
(I have 361 nuts, in a 19x19 grid... My fingertips hurts!)
JeromyReno
Post by JeromyReno » Wed Sep 30, 2015 5:10 pm
im doing the same thing but I had a ton of these 6mm threaded cam locks made.
Gadgetman!
Post by Gadgetman! » Wed Sep 30, 2015 5:37 pm
There's a problem with those nuts that someone should have mentioned earlier...
Unless they sit very tightly, it's possible to accidentally push them back out if you insert the bolt a bit too roughly.
designxtek
Post by designxtek » Thu Oct 01, 2015 6:33 am
JeromyReno wrote:im doing the same thing but I had a ton of these 6mm threaded cam locks made.
How do those work?
designxtek
Post by designxtek » Thu Oct 01, 2015 6:39 am
Done for now. I'm almost out of T-Nuts.
Screen Shot 2015-09-30 at 11.35.49 PM.jpg (169.25 KiB) Viewed 2463 times
apspurgeon
Post by apspurgeon » Thu Oct 01, 2015 8:27 am
I did a similar thing with t-screws, and found that holding the object in place with hot glue worked extremely well. Have milled wood and aluminium....no issues with movement.
DRobs86
Post by DRobs86 » Fri Oct 02, 2015 5:56 am
Hot glue? As in you hot glue a workpiece?.... Or you put in tee nuts then hot glued tee nut on the back to keep it inserted?
Post by WillAdams » Fri Oct 02, 2015 10:47 am
The CAM locks work much the same as the eccentric nuts — look at the shapes and hole placement, then envision how things would move when the mechanism was worked.
I believe we have links for them on the wiki: http://www.shapeoko.com/wiki/index.php/ ... mp_Designs
See
apspurgeon
Post by apspurgeon » Sat Oct 03, 2015 12:53 am
Hi there, I hot glue the working material to the waste board without anything else (e.g no clamps)
