Shapeoko 3 tolerance
designxtek
Post by designxtek » Tue Oct 20, 2015 3:38 am
Does anyone know the tolerance of the shapeoko 3?
I had some pockets that are suppose to be 10.15mm width and my shapeoko is doing 10mm pockets.
My 3D printer is getting within 10.05mm.
Seems like my S3 is +/-0.15mm
CastIrony
Re: Shapeoko 3 tolerance
Post by CastIrony » Tue Oct 20, 2015 3:58 am
That sounds pretty close to the 0.005 inch expected accuracy. You might get it better through careful calibration and squaring.
Post by WillAdams » Tue Oct 20, 2015 9:24 am
I believe upgrading belt width helps on this.
The other thing to try is a finishing pass w/ roughening clearance suitable to leave an optimal size chip. Experimenting w/ path direction may help w/ backlash here.
What sort of results did you get when calibrating using what method?
designxtek
Post by designxtek » Fri Oct 23, 2015 3:33 am
I'm waiting for my Nomad 883. I'm mainly going to use the shapeoko for roughing and Nomad for finishing. Just curious of the tolerance on my S3. :D
WoodNDust
Post by WoodNDust » Sun Oct 25, 2015 7:52 pm
designxtek wrote:I'm waiting for my Nomad 883. I'm mainly going to use the shapeoko for roughing and Nomad for finishing. Just curious of the tolerance on my S3. :D
I would be interested to know more about your experience with fine tuning your Shapeoko 3, if you go that route; for example, if you were to upgrade your belts to GT3's. Anyhow, a Shapeoko 3 and Nomad 883 combo will surely get you places.
Post by cvoinescu » Sun Oct 25, 2015 8:07 pm
Is the Nomad that much better?
designxtek
Post by designxtek » Sun Oct 25, 2015 9:21 pm
cvoinescu wrote:Is the Nomad that much better?
we will see
Gadgetman!
Post by Gadgetman! » Sun Oct 25, 2015 9:35 pm
It has ball screw rods or something, and promises a repeatability of 0.001" (0.0254mm )
It also has a tool-length probe to automatically measure the length of the toool(Z-axis homing).
I have a bit of an issue with that repeatability, though, as that's the same as the listed run-out on their spindle.
That would mean that the rods are almost perfect, that the spindle mount is rock solid, there's no measurable deflection anywhere...
I'm giving them the benefit of the doubt and assuming that it's better than 0.004" but 0.001" I won't believe before I see it with my own eyes.
Or?
The website is all about the Nomad 883 Pro?
Wasn't it just 'Nomad 883' before?
Post by WillAdams » Sun Oct 25, 2015 10:54 pm
Yes, the Nomad is to be upgraded to a “Pro” model, due to a mis-order of too-large parts.
The Pro version takes advantage of said parts, and has some modifications to make assembly easier, and to reduce parts count, taking advantage of 5-axis machining.
Thread on it on their forums.
WoodNDust
Post by WoodNDust » Mon Oct 26, 2015 3:01 am
WillAdams wrote:Yes, the Nomad is to be upgraded to a “Pro” model, due to a mis-order of too-large parts.
I'll have to check that out. Thanks for the info.
