How to smooth sharp edges in aluminum
tomb18
Post by tomb18 » Sun Dec 13, 2015 10:27 pm
Hi
I've made a few aluminum parts and was wondering how you smooth the edges of the cuts. There a combination of pockets and outside profile cuts.
Do you use a ball head mill and turn the part over? Or do you use a file? Or sand paper?
Thanks for advice.
Tom
sgth0mas
Re: How to smooth sharp edges in aluminum
Post by sgth0mas » Sun Dec 13, 2015 11:26 pm
If you are looking for rounded/radiused edges...you want to use a corner rounding end mill. Examples in link below:
http://www.harveytool.com/cat/Corner-Ro ... s_200.aspx
If you are just trying to break sharp edges, a file will work as well as other debur tools.
Estlcam
Post by Estlcam » Sun Dec 13, 2015 11:30 pm
You can use a blade (e.g. large box cutter) and just scrape along the edges.
(Do not cut into the material - the knife edge points away from the direction of movement).
This works fairly well (and is also the working principle of professional deburring tools).
But don't use expensive knifes - they will be damaged.
Post by WillAdams » Mon Dec 14, 2015 12:04 am
There are specialized tools for this: http://www.grainger.com/category/machin ... alog/N-c3b
tomb18
Post by tomb18 » Mon Dec 14, 2015 5:23 am
ok, thanks for the tips.
Post by WillAdams » Mon Dec 14, 2015 12:33 pm
Added this to: http://www.shapeoko.com/wiki/index.php/ ... ssing_Cuts
Any other techniques / tools which people are using?
Fablicator
Post by Fablicator » Mon Dec 14, 2015 1:17 pm
I either use a 45 deg Vee bit to break edges, 400 grit sandpaper, or a Fiber abrasive buff on my Dremel.
Estlcam
Post by Estlcam » Mon Dec 14, 2015 2:03 pm
A good, sturdy router table with chamfer bit also works very well for small chamfers (1x1mm is OK / 2x2mm with caution / 5x5mm is asking for trouble).
But this is only suitable for large, flat parts you can hold securely - do not do this with small or irregular shaped things - its just too risky.
Will Winder
Post by Will Winder » Tue Dec 15, 2015 8:53 pm
In the past I would clamp the part in my bench vice and hit the corners with a file - which I still have to do for removing tabs.
This summer I found a vibratory tumbler at a yard sale which I'll try for this in the future (not my video):
https://www.youtube.com/watch?v=S2olHGE0R54
