Wobble in x axis lines.
Knotty_Dawg
Post by Knotty_Dawg » Fri Dec 25, 2015 2:03 am
Making some cribbage boards tonight and fing that I have a wobble along the x axis when routing straight lines. Happens at the same place in parallel lines.
Went over the v track bearings, all seem tight.
Picture sort of shows it, just barely noticeable deviation.
Reduced feed 50%and the same wobble occurs.
Could it be a slightly out of wack v bearing?
Any ideas?
Georgei
Re: Wobble in x axis lines.
Post by Georgei » Fri Dec 25, 2015 11:37 am
Check the repeat distance of the wobble. If it is the same as the perimeter of the wheels that means that one (or more) of your X wheels have ball bearings that they are wobbly or not correctly fitted in the wheels.
George
Post by WillAdams » Fri Dec 25, 2015 1:11 pm
Insightful diagnosis!
Not a problem I can recall having come up, and am faintly surprised at that.
Knotty_Dawg
Post by Knotty_Dawg » Fri Dec 25, 2015 7:40 pm
I think you may be on to something there.
Also found evidence that one of the belt bearings is making contact with the rail.
Knotty_Dawg
Post by Knotty_Dawg » Mon Dec 28, 2015 1:45 am
It was a bad v-wheel on the X axis.
One side of the v alternates thick to thin and is shifting the Z axis assembly.
Now to order a few spares.
Are the ones from Inventables the same? https://www.inventables.com/technologie ... -wheel-kit
Or is there another source(s)?
46730446-6136-4ea2-b5f9-81beca21bcee (1).jpg (25.12 KiB) Viewed 1234 times
Post by WillAdams » Mon Dec 28, 2015 1:55 am
Parts sources are listed on the parts overview page: http://www.shapeoko.com/wiki/index.php/Parts#All_Axes
Post by edwardrford » Mon Dec 28, 2015 11:29 pm
Knotty_Dawg wrote:It was a bad v-wheel on the X axis.
One side of the v alternates thick to thin and is shifting the Z axis assembly. Now to order a few spares.
As always - PLEASE contact support if you run into a problem like this! We'll get you fixed up right away.
Edward
Knotty_Dawg
Post by Knotty_Dawg » Thu Dec 31, 2015 3:21 pm
I never even thought to contact support.... :shock:
Sent off an email.
