Shapeoko 3 Z-Axis stepper skipping
Re: Shapeoko 3 Z-Axis stepper skipping
Post by WillAdams » Fri Dec 02, 2016 8:19 pm
That number is in line with what we have in the wiki:
http://www.shapeoko.com/wiki/index.php/ ... ifications
Normally cutting forces are in the single digits (for pounds), so it's surprising that it fails when cutting, and it being caused by a board fault seems plausible.
richb
Re: Shapeoko XXL Z-Axis stepper skipping, spring mod
Post by richb » Sat Dec 03, 2016 4:16 pm
Measured some more data. Using a shipping scale mounted at several heights jogged the spindle down until Z axis stepper skipped. See the plotted data below for the standard springs supplied with Shapeoko XXL machine and replacement Hillman springs from Lowes.
Plotted Data
This seems to show that the standard springs are too strong and that most of the Z axis thrust is overcome by these springs in the lower spindle positions. That would explain the loss of the Z axis positioning. But using the longer Hillman springs results in a more constant force and available thrust.
Based on these measurements does it look like my machine and controller are operating correctly? For complete data and photos see the attached pdf.
Shapeoko-Zthrust.pdf
Complete Data and Pics
(136.29 KiB) Downloaded 97 times
houndel
Post by houndel » Sun Dec 04, 2016 6:15 am
I've been having the same issue for months - I stopped using the shapeoko 3 because this inhibits all operations. 0.5mm is the best z depth plunge I can reliably hold in MDF or clear pine (without loosing depth from the stepper skipping).
Recently I gave it a go with a very simple drilling operation using UGS: after several peck drills (each time skipping) UGS threw up a "hard limit hit" warning, and cut all control to the shapoko, dropping the still running spindle into the work piece. Not ideal.
Just as you described - the issue doesn't seem to be mechanical unless it's happening inside the stepper. There's a "thunk" noise when it skips as if it has bottomed out onto something too hard to cut. I have tightened all the belts a number of times a few different ways, and the pulley is definitely not slipping on the shaft.
I am very keen for any new ideas to try.
Post by WillAdams » Sun Dec 04, 2016 2:48 pm
For the limit switch hit issue, this is likely why the Carbide 3D homing switch which uses unshielded wires only implements soft limits --- try shielded wires? twisting them doesn't seem to be sufficient for preventing interference. Also review your grounding and ensure that you have a star topology with no ground loops.
I believe the "Thunk" sound inside the stepper motor is the stepper losing position and being forced to the next position which it wants to hold --- try removing or replacing the springs --- I am beginning to suspect that the springs which were well-suited for the original, tall plate, aren't suited for the new shorter one --- probably people who are being successful have added in spoil boards and are mounting the router at the top position, both of which reduce the need for the greater extents of downward travel.
Try removing a spring?
I actually considered and worked up a B.O.M. for changing the machine over to a leadscrew Z-axis: http://www.shapeoko.com/wiki/index.php/ ... Acme_screw
richb
Post by richb » Mon Dec 05, 2016 5:06 am
The "thunk" sound is definitely what I was hearing when losing Z-axis position.
Interesting... last week when I spoke with Apollo at Carbide3d about these problems he DID say I might have to remove one of the Z-axis strings.
Changing the machine over to a leadscrew Z-axis sounds interesting and (I think) has an advantage of eliminating uncontrolled or run-away plunge when the bit is pulled into the work piece. I had this happen once when switching from a 2-flute to a 3-flute bit without updating the tooling settings. BAD mistake on my part!
Post by WillAdams » Thu Dec 08, 2016 4:55 pm
After discussing this a bit it seems likely that such problems are caused by insufficient Z-axis belt tension (or maybe a bad motor) --- the stepper motor should be able to overcome the springs and then some. Agree removing a spring is a useful test / technique.
ajleone11
Post by ajleone11 » Thu Mar 02, 2017 1:11 am
I was having the same problem and tried removing one spring. Seemed to work fine after but can the machine run on one spring for an extended time and if not, what would be a good replacement spring?
Tony
fshrmn1
Post by fshrmn1 » Sun Jun 06, 2021 7:45 pm
My dust collector brush is stiff enough to make mine skip...even got a new stepper and same issue???
cakoceag874
Post by cakoceag874 » Mon Jun 28, 2021 2:44 am
Red Bottom Shoes
Air Jordan 4
Moncler Store
Jordan Retro 3
Fjallraven Kanken
Jordan Win Like 96
Jordan Retro
Valentino Shoes
Golden Goose
Pandora Jewelry Official Site
Yeezys
Air Jordan 12
Nike Air Max 95
Golden Goose Sneakers
Jordan 5
New Jordans 2018
GGDB Shoes
Pandora Rings
Moncler Jacket
Adidas Yeezy
Jordan Retro 11 Mens
Golden Gooses Sneakers
Pandora Bracelets
Air Jordan Shoes
Moncler Vest
Moncler Outlet Store
Jordan Shoes
Kyrie Irving Shoes
Pandora Ring
Air Max 90
Mens Nike Shoes
Outlet Golden Goose
Cheap Nike Shoes
James Harden Shoes
Jordan 11
Pandora Jewelry
Jordan 8
Jordan 6 Retro
Air Jordan 6 Retro
Jordan Shoes For Women
Red Bottoms Shoes
Christian Louboutin shoes
Air Max 270
Pandora Canada
Pandora
Hermes Birkin
Golden Goose Shoes Women
Jordan 9
Pandora Jewelry
Jordan 11s
Air Jordans
Air Jordan 5
Nike Huaraches
Adidas Yeezy
Jordan 10
Nike Outlet Store Online Shopping
Golden Goose Mid Star
Adidas NMD R1
Jordan 1
Yeezy Shoes
Air Jordan
Moncler Outlet
Air Jordan Sneakers
Shoes GGDB
Jordan 11
Pandora Official Site
Nike Shoes For Women
Fitflops Sale Clearance
Yeezys
Nike Factory Outlet
Nike Air Max 98
Air Jordan 3
Jordan 14
Air Jordan
ECCO
Jordan 12
Air Jordan 4 Retro
Jordan Retro
Pandora Jewelry
Nike Outlet Store
Moncler Jackets
Soccer Shoes
Ferragamo Outlet
Air Jordan 11s
Jordan 11 GYM Red
Nike Air Force 1
Jordan 4 Retro
Jordan 6
Jordan 12 Retro
Nike Shoes
Women Nike Shoes
GGDB Sneaker
Ferragamo Outlet
Jordan 11
Air Jordan
Pandora Charms
Adidas NMD
Golden Goose Sale
Jordan 12 Retro
Moncler Jackets
Yeezy
Nike Outlet Store
Retro Jordan
Nike Snkrs
Nike Factory
Nike Sale
Pandora Jewelry
Air Max 2018
Jordan Retro 11
Red Bottom Shoes
Air Jordan Retro
Jordans 4
New Jordan 11
Jordan Retro 5
James Harden shoes
Jordan 13s
Jordan Sneakers
Louboutin Shoes
Nike Official
Air Jordan 11
Pandora Charms
Air Force 1
Moncler Jackets Outlet
Cheap Jordans
Air Jordan Sneakers
Nike Shoes Outlet
Jordans 2021
Golden Goose Outlet
Triple S Balenciaga
Fitflop Shoes
Jordans Sneakers
Nike Air Max
Balenciaga Sneakers
Jordan 11
Moncler
cakoceag874
Post by cakoceag874 » Thu Jul 01, 2021 1:52 am
Air Jordan 17
Air Jordan 33
Jordan 18
Air Max
Jordans 19
NBA Uniforms
Nike Blazers
Wholesale Nike Shoes
NHL Shop
Adidas Store
Air Jordan 28
Air Force 1
Nike Foamposite
Jordan 30
Jordan 4
Air Max
Air Force 1s
Pandora Bracelet
Custom Jerseys
Nike Free Rn
Nike Jordan 1 Low
Jordan 2s
Jordans 20
Air Jordan 31
Air Force 1 Men
Jordan 23
Jordan 11 Low
Nike Outlet
Air Max 2019
Nike Shoes
Air Force Ones Nike
Adidas Yeezy Boost 350
Jordan 11
Jordan 33
Cheap Jordan Shoes
Jordans 24
Nike Shoes For Men
Air Jordan Retro 12
New Nike Shoes
Jordans 27
Wholesale Nike Shoes China
Nike Free
Best Nike Running Shoes
Fjallraven
Jordans 12
Nike AF1
Nike Running Shoes
Baby Jordans
Nike Cyber Monday 2019
NHL Jerseys
Nike Shoes
Jordan Shoes For Kids
Air Max 720
New Jordans 2021
Nike Outlet
Nike Outlet Online
Nike Canada
Nike Lunarlon
Jordan 1
Adidas China
Nike Zoom
Nike React
Pandora Charms
Nike Air Force
Nike Sneakers
Dior Jordans
Adidas Wholesale China
Pandora Ring
AJ1
Nike Shoes
Nike Shox
Jordan 11 Retro
Jordan 6s
Yeezy Butter
MLB Shop
Adidas Shoes
Nike Womens Shoes
Jerseys Wholesale
Lebron James Sneakers
Huarache
Christian Louboutin
Jordans Wholesale Suppliers
Red Bottoms Louboutin
Cheap Jordans Free Shipping Wholesale
Adidas Shoes Canada
Nike Shoes Outlet Store Online Shopping
Nike Air Max 270
Pandora Canada
Cheap Jordan
Pandora Jewelry 70% off Clearance
Nike Wholesale
Nike Clearance
Air Jordan
Nike Flip Flops
Jordan Shoes
What The Jordan 5s
Nike Wholesale
Pandora CZ Charms
Adidas Yeezy Official Website
Christian Louboutin Outlet
NFL Shop Online
Off White x Nike
Nike Factory Store
Jordan 33
Jordans 13
Cheap Wholesale Nike Shoes Free Shipping
Adidas Outlet
Nike Running Shoes For Women
Jordan Retros
Jordan 12 Retro
Nike Outlet Store
Wholesale Shoes
Jordan 11 Concord
New Nikes
Nike Shoes Wholesale
Nike SB Dunk
Jordan 14
Nike Jordans
NMD
Nike Huarache
Nike Shoes
Nike Blazer
Jordan Shoes
Jordan 15
Nike Air Foamposite
Cheap Shoes Wholesale
Jordan 21
Pandora Jewelry
Jordans 22
Jordans 26
Nike Air Max 270
Air Jordan 13
Jordan 34
Nike Shoes Canada
Air Jordan 32
Huarache Shoes
Cheap Jerseys From China
Jordan 16
Nike Zoom Pegasus
Cheap Jordan Shoes From China
Cheap Nike Shoes From China
Nike Store
Wholesale Jordans From China Factory
Cheap Jordans From China
Nike Outlet
Nike Shoes
Jordan 29
Air Jordan 25
Nike Outlet
Pandora Jewelry
Jordan 35
Pandora Rings Official Site
Nike Wholesale
