Tooling Sale
samc99us
Tooling Sale
Post by samc99us » Thu Jan 21, 2016 7:42 pm
Just an alert MSC is having a sale on tooling, 35% off today, code CTB35H. That's a pretty darn good deal and I should have slapped more onto my order. As is it saved me $20 on one end mill (5 degree tapered end mill).
http://www.mscdirect.com/browse/Milling ... d=12106227
CastIrony
Re: Tooling Sale
Post by CastIrony » Thu Jan 21, 2016 9:57 pm
Somewhat offtopic: I haven't yet developed a good sense for why similar-looking end mills made out of the 'same' material (e.g. 'solid carbide, uncoated') have wildly different prices depending on where you get them.
I'm sure there often is a difference, whether from design or quality of materials or different manufacturing techniques or better tolerances or whatever, but none of that seems to be conveyed in product listings that I can tell. It's hard enough some times searching for easy stuff like shank diameter or helix angle.
Is it safe to always assume that more money = better? Is a $30 mill going to be worth not getting two 'equivalent' $15 mills?
sgth0mas
Re: Tooling Sale
Post by sgth0mas » Thu Jan 21, 2016 11:17 pm
CastIrony wrote:Somewhat offtopic: I haven't yet developed a good sense for why similar-looking end mills made out of the 'same' material (e.g. 'solid carbide, uncoated') have wildly different prices depending on where you get them.
Coatings, grade of carbide, tolerances, research into cutting geometry and other factors typically drive cost.
More expensive isnt always better (i have some $50+ tapered bits that i would say were way overpriced given the life), but cheap is strongly correlated with lower quality. It really depends on the use.
Ive been using O flutes from amana lately and those are definitely worth the price. I wish i had this sale when i bought several of them.
Thanks for posting this OP
samc99us
Re: Tooling Sale
Post by samc99us » Fri Jan 22, 2016 1:07 pm
I can't really answer the question either, on what makes a more expensive tool drastically better. Certainly coatings play a factor. For most of what I do, the tools I buy from Lakeshore are just fine and they now have two flute TiCN (aluminum compatible) cutters for ~$15. All my lakeshore tools measure a little bit under but are generally close-0.123" for a 0.125" end mill for example, whereas the cheaper ebay tools and inventables end mills are more like 0.117" for a 0.125" cutter.
I went to MSC for a specialty tool, an SGS end mill: http://www.mscdirect.com/product/details/03280849
I hope this isn't a bad tool, but the type of cut I will be using this for is a one-off deal basically, and I'm not loading the tool in a slot, so it should be fine if I treat it nicely!
