Where to buy Nema 23's stepper motors? (Canada)
jininjin
Post by jininjin » Thu Feb 04, 2016 1:50 pm
I have only found a couple on ebay that match what I am looking for. Is there any places that I should look. Preferably in Canada but If I need to I will buy outside.
Motor Specs:
Nema 23
3.2v
2.8a
1.8 step angle
10.1 kg-cm(140 in-oz) to 18.9 kg-cm (262 in-oz) Holding Torque
Side question: Does it matter if I have higher torque on the X axis compared to the rest of the machine?
Edit: 1.8 step angle not 2.8
Shapeoko 2
X,Y,Z Nema 23's 140 in-oz, ACME Z Axis, Quiet Cut Spindle 400w
ChiliPeppr, TinyG V8
Re: Where to buy Nema 23's stepper motors? (Canada)
Post by WillAdams » Thu Feb 04, 2016 2:18 pm
We list some Canadian suppliers at: http://www.shapeoko.com/wiki/index.php/Vendors
and some specific order links (mostly for NEMA17 though) at: http://www.shapeoko.com/wiki/index.php/Parts#Motors
Stepper Motor selection is discussed to some degree at: http://www.shapeoko.com/wiki/index.php/Stepper_Motors
The important thing is the Y-axes must match --- the X-axis, working alone, would likely benefit from more torque.
bharbour
Post by bharbour » Thu Feb 04, 2016 2:36 pm
I just purchased something similar from http://us.stepperonline.com/. Not sure if that'll meet your needs or not.
wunderaa
Post by wunderaa » Thu Feb 04, 2016 4:19 pm
Options through automation direct for NEMA23's.
http://www.automationdirect.com/adc/Sho ... 22&start=0
kayaker
Post by kayaker » Thu Feb 04, 2016 6:37 pm
jininjin wrote:I have only found a couple on ebay that match what I am looking for. Is there any places that I should look. Preferably in Canada but If I need to I will buy outside.
Motor Specs:
Nema 23
3.2v
2.8a
2.8 step angle
10.1 kg-cm(140 in-oz) to 18.9 kg-cm (262 in-oz) Holding Torque?
2.8° Stepper? That would be 360° / 2.8° = 128.5714285714286 steps per revolution. Do you mean 1.8°?
In Canada:
Try Phidgets: http://www.phidgets.com/products.php?category=23
or
RobotShop: http://www.robotshop.com/en/stepper-motors.html
Take Care,
Jim. . .
In the immortal words of Dr. Johnny Fever; "when everybody is out to get you, paranoid is just good thinking!"
jininjin
Post by jininjin » Fri Feb 05, 2016 3:25 am
Thanks for all the speedy answers! You all rock!
kayaker wrote:2.8° Stepper? That would be 360° / 2.8° = 128.5714285714286 steps per revolution. Do you mean 1.8°?
Oops Sorry that was a typo, I did mean 1.8
WillAdams wrote:The important thing is the Y-axes must match --- the X-axis, working alone, would likely benefit from more torque.
That's Great news, I will probably get a higher torque stepper motor then.
Although I just read that Wiki Linkhttp://www.shapeoko.com/wiki/index.php/Parts#Motors. It says up to a maximum of ~125 oz./in? Is this right or is it just recommended? I currenlty have 140oz/in and might spring for the 262oz-in for the X axis.
I am reading more... lots to understand about motors..
Shapeoko 2
Post by WillAdams » Fri Feb 05, 2016 4:01 am
125 oz. in. is what's suggested in terms of price / performance / weight, in light of the weight of the machine, and the cuts it can take people have used more powerful, most notably I.C., but c.f.,
http://www.shapeoko.com/wiki/index.php/ ... _23_motors
Still not certain where the point of diminishing returns for the SO3 is.
jininjin
Post by jininjin » Fri Feb 05, 2016 5:04 am
WillAdams wrote:125 oz. in. is what's suggested in terms of price / performance / weight, in light of the weight of the machine, and the cuts it can take people have used more powerful, most notably I.C., but c.f.,
More info! Thanks. Ok now I'm thinking to stick with 140 oz/in. It appears there is a tradeoff of weight, torque and the machines capabilities.
I found this great explenation from Inventables http://blog.inventables.com/p/stepper-motors.html
Shapeoko 2
