Drawing a half circle in Carbide Create?
roboto
Post by roboto » Fri Feb 05, 2016 8:01 pm
Hi everyone,
I need some help figuring out how to draw a half circle (Basically a "U") and can't figure out how to cut the top of the circle off. Anyone have a better grasp on the Carbide Create drawing tools than me?
Gamble
Re: Drawing a half circle in Carbide Create?
Post by Gamble » Fri Feb 05, 2016 9:09 pm
Not sure what you mean by a half circle as a U. But if you draw a circle, then a box and set them on top of each other, you can do a boolean union or weld in other programs. Then go to edit mode and manually delete or add nodes. That should get you started to where you need to be
CNC Plasma Table
Tig, Mig Welders
Shapeoko3
UltiArjan
Post by UltiArjan » Fri Feb 05, 2016 11:15 pm
Yep, it's in there...
Shapeoko3 #1331, Makita RT0700
Ultimaker2, Ultimaker2+E3Dv6 (abs only)
