Using Shapeoko 3 to drill 1/8 thick aluminum.
Fablicator
Re: Using Shapeoko 3 to drill 1/8 thick aluminum.
Post by Fablicator » Fri Feb 19, 2016 2:51 pm
jkanzaki wrote:Reporting back I tried peck distance of .02" / .5mm with plunge rate 2IPM @ 8000 spindle RPM.
My end mill broke at the second hole.
I am considering increasing the spindle RPM.
I've only ever had success at 1ipm plunge or less, and I can see the axis flexing and the belt go half slack. I have no speed control on my 611.
Now, I go down an end mill size and use a helical bore for better results.
jkanzaki
Post by jkanzaki » Fri Feb 19, 2016 6:57 pm
is helical bore a special operation?
Shapeoko 1 - dissassemble
Shapeoko 2 - 1 x 1m expansion TinyG, superPid, Dw660, Aluminum extrusion bed, Nema 23, acme, Z axis upgrade, Dual Y
Shapeoko 3 - 0051 Stock Dw611, SuperPid, limit switch, 9mm belt
Fablicator
Post by Fablicator » Fri Feb 19, 2016 8:09 pm
Special-ish. It's its own thing in fusion 360.
You could get close just doing the hole as standard pocket with multiple depths.
https://www.youtube.com/watch?v=hGcwAaUooo0
jkanzaki
Post by jkanzaki » Sat Feb 20, 2016 6:41 am
Fablicator wrote:Special-ish. It's its own thing in fusion 360.
I'll learn fusion 360 but I probably won't redo all my cam operation in fusion 360 for my current job.
Thanks for the tip.
jkanzaki
Post by jkanzaki » Sat Feb 20, 2016 11:56 am
CrazyBillybob wrote:Henry,
you might want to setup a job to spot all the holes with a bit more like this. http://www.ebay.com/itm/1pc-1-8-x-90-Co ... Sw5IJWeVL5
Even a 1/8" drill will want to drift abit. The circuit board drills have a flatter point because the material they are designed to cut is softer but more abrasive, they will wonder more then a more conventional 118deg bits.
A bit of lube (wd40, boelube, etc) will keep them sharper longer but @ $0.60 each if you chew a couple up your still not out a bunch.
Good Luck,
CBB
Hi CBB thanks for the recommendation, I will consider buying getting some. You are right, no matter how slow I go the pcb drill bit will wonder off a little bit.
AnonymousPerson
Post by AnonymousPerson » Fri Feb 26, 2016 11:05 pm
It might be interesting to try mounting an auto centre punch on the CNC, to provide some dimples in the metal first.
eg: http://www.amazon.co.uk/dp/B001RGQP50
Anyone tried this already? :)
Jimf
Post by Jimf » Sat Feb 27, 2016 2:58 am
I always use a center drill to start the holes. It's one extra step but it will always make sure the hole is placed at the correct location.
Post by cvoinescu » Mon Feb 29, 2016 12:58 pm
AnonymousPerson wrote:It might be interesting to try mounting an auto centre punch on the CNC, to provide some dimples in the metal first.
I have one of those (same bottom-of-the-barrel "brand" name), and either mine is very badly made, or I don't understand how to use it. First, the tip is not hardened, so after a few uses on mild steel mine got a tiny mushroom tip, not a point anymore; second, the mechanism works only if held and pressed in a certain way; and third, it requires quite a bit of pressure to punch, so I doubt the Shapeoko can press it that hard and not flex and lose accuracy.
A center drill sounds like a much better idea.
CrazyBillybob
Post by CrazyBillybob » Mon Feb 29, 2016 1:22 pm
+ 1 to Cvolinescu comment!
Post by WillAdams » Mon Feb 29, 2016 1:54 pm
I’ve never known a machinist to use the automatic center punches for anything other than rough work.
For accuracy, every one that I’ve worked w/ used a magnifying glass and a hammer — sometimes combined into a single tool: http://www.starrett.com/metrology/produ ... -Tools/815
