Expansion packs announced
HDVideo
Re: Expansion packs announced
Post by HDVideo » Thu Feb 25, 2016 8:12 pm
I guess my confusion of the chosen sizes stems from the Wiki statement (I think it's still there), that sizes up to 5'x10' should be possible, I assume that was based on testing of the extrusion. So 33x33 seemed an odd choice given the stated capabilities of the parts and the fact that 48x48 was by far the most requested size in the poll. Whatever, I'm sure Edward gets a kick out of all our speculation and second-guessing. lol
chamnit
Post by chamnit » Thu Feb 25, 2016 8:18 pm
AnonymousPerson wrote:If someone figures out a good way to join the extrusions, you could join XL rails to the existing S3 ones. That would fit your 48x24" cutting area inside. :)
That's an interesting idea. With the spare parts from an XXL upgrade, you'd have three ~24" rails to play with. I think you could reasonably bolt them together because the walls are 1/4" thick and can hold a good thread. Extending the two y-axis rails would be theoretically possible without sacrificing rigidity too much.
AnonymousPerson
Post by AnonymousPerson » Thu Feb 25, 2016 10:05 pm
chamnit wrote:I think you could reasonably bolt them together because the walls are 1/4" thick and can hold a good thread. Extending the two y-axis rails would be theoretically possible without sacrificing rigidity too much.
A quick concept version:
Extrusion join plate concept 1 screenshot 1.jpg (105.18 KiB) Viewed 623 times
Using a two-plate solution. Plate A is bolted to one extrusion using countersunk M5 bolts. Plate B is bolted to the other extrusion, also using countersunk M5 bolts. The two plates mesh with each other, and are bolted together with M8 bolts.
Looks kind of over-engineered.
Extrusion join plate concept 1 screenshot 2.jpg (92.7 KiB) Viewed 623 times
Extrusion join plate concept 1 screenshot 3.jpg (83.02 KiB) Viewed 623 times
Note - the extrusion dimenstions aren't accurate, I just walked over to my S3 with a ruler. ;)
Pretty sure the wall thickness of the extrusion was a lot thinner in the real thing. The bolt sizes are pure guess work, etc.
AnonymousPerson
Post by AnonymousPerson » Thu Feb 25, 2016 10:08 pm
The concept model files (STEP format, zipped with 7-Zip), in case anyone wants to muck around with them. :)
Extrusion join plate concept - with extrusion.7z
(177.71 KiB) Downloaded 22 times
These links should let people grab the project files, potentially in various useful formats:
For anyone with Fusion 360, the above links might "just work" for loading them directly too.
Hopefully that's useful. :)
Post by twforeman » Fri Feb 26, 2016 12:31 am
Wow, that seems a bit over-engineered. :)
Just bolt four lengths of 1/4 steel plate inside, one on each face.
Ender 3 3D Printer
AnonymousPerson
Post by AnonymousPerson » Fri Feb 26, 2016 12:46 am
twforeman wrote:Just bolt four lengths of 1/4 steel plate inside, one on each face.
Gah, didn't think of that. :D
Post by twforeman » Fri Feb 26, 2016 12:54 am
It's okay, I also suffer from "over-engineering disease" myself. :lol:
Ender 3 3D Printer
dvdsnyd
Post by dvdsnyd » Fri Feb 26, 2016 2:02 am
What about the spot the two sections come together. Wouldn't there be concern that the discontinuity would create a dip or some other height variation at that point?
sgth0mas
Post by sgth0mas » Fri Feb 26, 2016 2:06 am
dvdsnyd wrote:What about the spot the two sections come together. Wouldn't there be concern that the discontinuity would create a dip or some other height variation at that point?
JB weld, sand paper and patience:)
Defy
Post by Defy » Fri Feb 26, 2016 5:05 am
Good welder and slow file.
