Why you should not run unattended
Re: Why you should not run unattended
Post by twforeman » Tue Mar 08, 2016 1:28 pm
Jimf wrote:I try not to leave machines unattended but sometimes you need to get another cup of coffee or bathroom break. I put a remote wifi camera in my shop that I can view on my phone.
The room is also equipped with several fire extinguishers and smoke alarms. Now that I have a laser cutter, it is very important to keep a eye on things.
Leaving the room for a minute or two is okay. It's the people who start jobs and go to bed, or the store, etc. that worry me.
I don't even like to run the 3D printer when I'm not home or sleeping. I hear about people running 40 hour prints and just shake my head. :o
Ender 3 3D Printer
Fablicator
Post by Fablicator » Tue Mar 08, 2016 2:06 pm
I would not let my Shapeoko go more than briefly unattended either, and certainly never on a first run of a part. There is just no way to adequately monitor whats going on between the bit and your work piece.
Most mid-high level 3D Printers should have enough safety features to prevent a fire, though. There are fewer (and easier) variables to control.
On the machines I use:
*The normal running temperatures are well below flash point if the something mechanical were to fail and the print head would get buried into the part.
*If the thermocouple were to become detached from the extruder head, the low temp warning would trigger and extrusion would stop.
*If the thermocouple were cut, it would read maxtemp and extrusion would stop.
*All wiring is properly rated, and the power supply and control electronics are contained within a metal enclosure.
AnonymousPerson
Post by AnonymousPerson » Tue Mar 08, 2016 2:09 pm
Jimf wrote:I saw a wifi enabled power strip that someone used for a 3D printer. Those printers can be a fire hazard if the hot print head goes thermal runaway. Not sure where you can find the power strip.
Hmmm, I have one of these in self storage overseas. Won't have access to it for a few months though:
http://www.wti.com/p-83-ips-800-ce-inte ... -8c13.aspx
Sounds like another project for the ToDo list, even if later on. ;)
KAScnc
Post by KAScnc » Tue Mar 08, 2016 3:30 pm
I've ran 70+ hour prints before. The best suggestion I can give is run the printer in a all metal cabinet with a camera and smoke alarm like this one. http://www.amazon.com/gp/product/B00GDH ... AN47WK6FSG
Thermal fuses and quality power supplies help as-well. As for the TCP/IP connected power distribution switch, I use a APC AP7900. You can find deals on ebay, about a 100 bucks..
jpmreno01
Post by jpmreno01 » Sat Jul 07, 2018 12:30 pm
What kind of camera can I install on my enclosure and view on my phone?
Sent from my SM-N950U using Tapatalk
CrazyBillybob
Post by CrazyBillybob » Sun Jul 08, 2018 3:24 am
I've been using a https://www.wyzecam.com/ wyze camera.They cost $19.99 and are pretty nice. I have one on my 3D printer so I can check it from anywhere on long prints. My 3d printer is connected to a wifi controlled outlet so I can cut the power if anything crazy happens. (Which I have done a few times when the print popped off the bed or one of the steppers missed a step or 50) I will be adding one to my CNC enclosure when I get the rebuilt finished.
CBB
I have no affiliation with the wyze cam company...just a happy customer.
jpmreno01
Post by jpmreno01 » Mon Jul 09, 2018 4:35 pm
CrazyBillybob wrote:I've been using a https://www.wyzecam.com/ wyze camera.They cost $19.99 and are pretty nice. I have one on my 3D printer so I can check it from anywhere on long prints. My 3d printer is connected to a wifi controlled outlet so I can cut the power if anything crazy happens. (Which I have done a few times when the print popped off the bed or one of the steppers missed a step or 50) I will be adding one to my CNC enclosure when I get the rebuilt finished.
CBB
Thanks for the info that's great info.
