Brush for dust shoe in europe
Hi all,
Does anyone know where I can source flexible brush strip for my dust shoe in Europe (ideally France)?
After several searches, I only find that kind of stuff on US websites (like for example on kentCNC) and the shipping cost is higher than the price of the brush itself...
OX CNC 750x500 - Makita Rt0700 - TinyG controller
Worklflow : Fusion 360 + Chilippepr
France
France
Re: Brush for dust shoe in europe
Hit the same problem here in the UK. After reading about alternatives, I went with this and it's working well:
http://www.amazon.co.uk/dp/B00GNAQE3I
Examples:
Examples:
- https://www.youtube.com/watch?v=-H0xENmig5E
- http://www.shapeoko.com/forum/viewtopic ... 602#p19780
- http://www.improbableconstruct.com/prod ... -for-dw611
Shapeoko 3 #516
I just use a transparency film.
thanks for your answers.
I think that I will end with that kind of solution
France
France
I bought a roll from Aliexpress. Just search under "cnc brush". Of course, you'll need to be patient as shipping will take a month.
I found that brush strips, even the softest ones, are two stiff. When the z access plunges downwards the z would have a hard time pushing it down. I tried them as an angle, but when the bristles end up in the pocket you are cutting they also would be hard to compress. Horse hair brush was a bit better cause they bend easier, but mounting them was harder cause the mount was a hard bulky, non bendable mount. I found my best brush so far has been a ⅛" thick rubber that I glued on and cut into strips.
This is with the thinnest softest brush mc master Carr sells. I'll post pictures of the rubber one when I get a chance
https://www.dropbox.com/s/6atwzo30xwbn2 ... .jpeg?dl=0
I could also only find stiff brushes, so I made a dust shoe that's not moving up and down with the router, I think it works pretty nice.
Also added a quick release for easy height adjustment and tool change;
https://www.youmagine.com/designs/shape ... ck-release
http://www.shapeoko.com/forum/viewtopic ... 6&start=10
Shapeoko3 #1331, Makita RT0700
Ultimaker2, Ultimaker2+E3Dv6 (abs only)
man that's great! i was thinking about making a skirt that goes around mine that doesn't move to so my shallow cut with a long bit and still get coverage.UltiArjan wrote:I could also only find stiff brushes, so I made a dust shoe that's not moving up and down with the router, I think it works pretty nice.
I tried brush strip and it was also stopping the Z axis plunging down. I ended up buying the cheapest, most basic foam mousepad I could find. It has a thin layer of plastic on one side, which gives it enough strength to hold its shape, but it moves easily over the material. And they cost about $5 each!
That is an excellent idea! I think I will try out something similar!UltiArjan wrote:I could also only find stiff brushes, so I made a dust shoe that's not moving up and down with the router, I think it works pretty nice.
Shapeoko 3 #1095 - Aluminium wasteboard, homing switches, Modified Z plate, Makita 700 router
Flashforge Dreamer Dual extruder 3D printer
2013 Ducati 848 Evo
2013 Ducati 848 Evo
