Please help new guy...
rocket2004
Post by rocket2004 » Sat Mar 26, 2016 5:58 pm
So this morning I ran my first test cutting of a gear I made in Gearotic,
then sent it to MeshCam in .dxf format. Then to Carbide Motion to cut.
It ran perfectly until it got down to about 75% done, then suddenly the feed rate
sped up all by itself and the spindle started to go nuts....out of control.
The gear was partially destroyed by the last few seconds before I shut it down....
Any ideas on why this would happen???
RR
AnonymousPerson
Re: Please help new guy...
Post by AnonymousPerson » Sat Mar 26, 2016 6:03 pm
Ouch, that doesn't sound good.
As a thought to rule out electrical weirdness, you could try running it again a few cm's in the air (not cutting anything). If the behaviour repeats itself, it's definitely something in the generated file, not an electrical thing.
Shapeoko 3 #516
rocket2004
Post by rocket2004 » Sat Mar 26, 2016 7:02 pm
Good idea.........except I would have to sit and watch it for 2.5 hours....
Thanks...
onekk
Post by onekk » Sat Mar 26, 2016 9:12 pm
Run the g code file into an emulator and see what happens. Or inspect the gcode, maybe it's some unsupported command tgat reset some motion comand to a rapid or set the feed rate wrongly.
Inviato dal mio Dynamic_Fun utilizzando Tapatalk
Post by WillAdams » Sat Mar 26, 2016 11:04 pm
Always preview / simulate.
For the tool path, it may be too many decimal points: http://www.shapeoko.com/wiki/index.php/ ... m_Expected
rocket2004
Post by rocket2004 » Sun Mar 27, 2016 7:00 am
Will,
I use Carbide Motion, there is no way to simulate anything.
Any ideas on a replacement for Carbide Motion?
RR
Post by WillAdams » Sun Mar 27, 2016 10:11 am
I’d thought that some sort of preview had been added in a recent update.
Please see: http://www.shapeoko.com/wiki/index.php/Software and the linked pages.
I use:
- Inkscape (and Macromedia Freehand and FontForge) for CAD
- MakerCAM and F-Engrave for CAM
- SCITE (a text editor) to reduce the number of decimals using a RegExp
- NCPlot (last free version) for editing and previewing G-code --- I should try NC-Corrector which is free
- bCNC for comm / control and previewing
Carbide Create and Carbide Motion worked fine (aside from a too-low feed rate) the one time I used them, and I’ve been meaning to do more w/ them, but have been busy.
DRobs86
Post by DRobs86 » Sun Mar 27, 2016 11:23 pm
rocket2004 wrote:Good idea.........except I would have to sit and watch it for 2.5 hours....
Thanks...
How large is this gear? 2.5 hours is a long runtime.
rocket2004
Post by rocket2004 » Mon Mar 28, 2016 7:52 am
8 inches..............in diameter.
