Well...moving away from the Shapeoko 2...
bharbour
Re: Well...moving away from the Shapeoko 2...
Post by bharbour » Mon May 16, 2016 3:04 pm
I've made a little progress on the new machine. I estimate I'm about 80% complete. I'm going to donate the 1mX1m Shapeoko2 to our local Maker Space.
Post by cvoinescu » Mon May 16, 2016 3:34 pm
Nice work, but be aware that the remaining 20% will take 80% of the time.
xfredericox
Post by xfredericox » Mon May 16, 2016 4:15 pm
i keep wondering, if you're going through that much trouble, why not build it in aluminium?
http://www.manmademayhem.com
bharbour
Post by bharbour » Mon May 16, 2016 4:42 pm
Price is the main thing, and rigidity another. I don't see an advantage in using expensive aluminum extrusions that won't give me any more rigidity (and could possibly be less rigid). My cousin is getting a water jet and if I can make the thing out of aluminum sheet...that would be something! But right now MDF will accomplish what I need it to do and very inexpensively.
xfredericox wrote:i keep wondering, if you're going through that much trouble, why not build it in aluminium?
samc99us
Post by samc99us » Fri May 20, 2016 6:27 pm
Make sure you seal the MDF. Stability across a wide range of temperatures and humidity levels is why Aluminum or steel win.
Another note, you probably need to pot your fasteners in some way. Over time, the vibration of machining will cause the wood screws or whatever attachment hardware you are using to back out. My modified Shapeoko 2 has mostly lock nuts in place for this reason.
bharbour
Post by bharbour » Mon May 23, 2016 1:41 pm
I understand what you're saying about screws backing out. Once I seated each woodscrew, I backed the screw out then wicked in some super glue to permanently harden the threads. Then when it was dry I put the screw back in. It was rock solid at that point.
samc99us wrote:Make sure you seal the MDF. Stability across a wide range of temperatures and humidity levels is why Aluminum or steel win.
bharbour
Post by bharbour » Tue Jul 19, 2016 1:42 pm
Have made some progress. Hopefully the Youtube vids below will work...
The first is the rolling chassis. I'm not all that happy with the table I built, but it works for now. I'm going to learn how to weld and build a steel table.
The second is the X working with the stepper. I'm using the Arduino-gShield combo to test it. I'll have discreet M542T drivers for the actual setup.
Post by cvoinescu » Tue Jul 19, 2016 2:46 pm
Good stuff!
Fixed the videos for you. Rather than the shortened URL [­youtube]https://youtu.be/...[­/youtube], use the full URL [­youtube]https://www.youtube.com/watch?v=...[­/youtube].
bharbour
Post by bharbour » Tue Jul 19, 2016 2:55 pm
Ahhhh...thanks!!!
cvoinescu wrote:Good stuff!
bharbour
Post by bharbour » Tue Aug 23, 2016 4:35 pm
Just a short vid of my new DIY machine drawing a 2X2 inch circle/square (which was a perfect circle and square...whew!). I'm working on getting the electronics in the enclosure then I'll cut my first part.
