Transposing and rotating G Code
DRobs86
Post by DRobs86 » Thu May 05, 2016 2:49 am
I often have the need to rotate G code in order to fit a random part in what I have left of a piece of stock. This is not planned in advance, or else I would nest it prior to my CAM work. Is there anything out there that reliably rotates an existing G Code file. I would be fine with a simple transposition of X to Y. Scaling would be nice too. I have found this:
https://sourceforge.net/projects/gcodetransposer/ .... but it looks to be out of active development and is written in Python. I usually find that I can write my own program by the time I can get one of these sourceforge/github hosted python programs to run.
Any recommendations?
Re: Transposing and rotating G Code
Post by WillAdams » Thu May 05, 2016 3:19 am
DRobs86
Post by DRobs86 » Thu May 05, 2016 3:52 am
Excellent. Thanks. I should have checked thebwiki first.
lxkhn
Post by lxkhn » Thu May 05, 2016 6:50 pm
DRobs86 wrote:Excellent. Thanks. I should have checked thebwiki first.
It's ok 99% of his day is posting wiki links anyway. ;)
PsyKo
Post by PsyKo » Fri May 13, 2016 5:51 pm
DRobs86 wrote:I often have the need to rotate G code in order to fit a random part in what I have left of a piece of stock. This is not planned in advance, or else I would nest it prior to my CAM work. Is there anything out there that reliably rotates an existing G Code file. I would be fine with a simple transposition of X to Y. Scaling would be nice too. I have found this:
The latest version of Goko allows such modification. The description can be found here : http://www.shapeoko.com/forum/viewtopic ... =10#p63689
Shapeoko #736
DRobs86
Post by DRobs86 » Sat May 14, 2016 1:05 pm
Thanks for the tip on Goko. I downloaded the 64 bit version for my 64 bit Windows 10. At first I got an error 13 and fixed that by deleting a pointer variable per a tip on stack exchange. Now I get a message that a JRE or JDK must be available to run Goko. For what it's worth, other Java apps still work.
Do I need to DL eclipse? A JDK?
PsyKo
Post by PsyKo » Sat May 14, 2016 2:39 pm
Hello,
What version of Java do you have ?
A simple JRE (at least 1.7) should be enough.
You should download the version matching your JRE and not necessarly the OS. If you have a 32bit JRE, then you should download the 32 bit version.
I think it's possible to have both 32 and 64bits Java on 64bit OS.
Let's me know if you have a problem.
Shapeoko #736
PsyKo
Post by PsyKo » Mon May 16, 2016 8:51 pm
DRobs86 wrote:Thanks for the tip on Goko. I downloaded the 64 bit version for my 64 bit Windows 10. At first I got an error 13 and fixed that by deleting a pointer variable per a tip on stack exchange. Now I get a message that a JRE or JDK must be available to run Goko. For what it's worth, other Java apps still work.
Any update on the subject ? Did you manage to get it to work ?
Shapeoko #736
DRobs86
Post by DRobs86 » Mon May 16, 2016 10:02 pm
Thanks for following up. I havent had tine to do any in depth investigating, but I am running x86 version of JRE 8.92. In fact, I recently upgraded to it.
The error persists. For what it is worth, I am able to run other java applications such as UGS.
Thanks again for checking in.
PsyKo
Post by PsyKo » Tue May 17, 2016 6:52 am
DRobs86 wrote: I am running x86 version of JRE 8.92. In fact, I recently upgraded to it.
Did you download the x86 version of Goko as well ?
Shapeoko #736
